I also looked at that set-up, the only problem is that the passenger grab bar is different on the JL than the JK. I don't think it will work. Supposedly Cool Tech LLC is coming out with a JL mount by the end of the month, but I haven't seen anything yet.
I don' think it would support a CB antenna. Although it is protected from wind, by the spare I still would not risk putting a fiberglass antenna on there.Looks great. Do you think it would be strong enough for a cb antenna? Like a firestick?
Nice Job!!!!!!!Well here it is....
This adhesive type mount does NOT provide a ground as there is no mechanical fastener to the panel it is attached to. The Comet B20 antenna is NOT a ground independent antenna and does require a ground at the antenna base. The panel of glass the antenna whip is next to has a grounded grid defroster grid on it and will act like a sheet of metal to RF. Even if you can get the antenna adjusted for a SWR of less than 1.5:1 it will be quite directional to the rear of the vehicle. The aesthetics of where you have it mounted may be really great but the functionality will be lacking at best.Well here it is....
So all the aux wires are run through the fuse box, correct? Just asking to make sure I won't need an inline fuse for my CB if I wire it to the "direct to battery" wires in the aux bundle.
