Vector Offroad JLU Highland Platform Cargo Shelf Aluminum
Vector Offroad
Rock Sponsor (Level 1)
Utah U.S.A.
vectoroffroad.com
2018 Wrangler JLU
Offroad Manufacturing
JLU HIGHLAND PLATFORM ALUMINUM $309.99
Proudly Designed and Manufactured in the U.S.A.
https://vectoroffroad.com/collections/jl-wrangler-products/products/jlu-highland-platform
You simply won't find a better quality cargo solution made In the U.S.A, for a better price.
Also Make sure to check out our JL CAGE Water Packs. They work perfectly with the JL Highland Platform
https://vectoroffroad.com/collections/jl-wrangler-products/products/jl-cage-packs
2018-current JLU
The deck of the JLU Highland Platform, now comes standard in bright brushed aluminum, instead of black powder coat steel. The benefits for our customers are weight savings, and cost savings.
The Vector Offroad JLU Highland Platform practically doubles the usable space in the rear cargo area. It's a must for overlanders, campers, or serious grocery getters! This high strength solution is a perfect place to put gear for your next adventure.
The JLU Highland Platform provides the following benefits:
  • Mounting hole patterns cut into the platform for RotoPax Water/Fuel/Storage mounts. The platform can hold up to two 4-gallon RotoPax containers on the underside of the deck
  • Weight of the Aluminum Highland Platform is ~15lbs
  • High Strength Aluminum, weight tested to 230 lbs without failure
  • Bolt-on installation, requires no permanent modifications to the vehicle.
  • Standard finish - Bright Aluminum Finish on Platform, and Powder Coat Steel Mounting Brackets
  • Multiple lashing points for straps and/or cargo nets.
  • Included quick release wing nut set allows easy removal of the main platform deck without the use of tools. Wing nuts allow for quick removal if you need to transport large items in the back of your rig from time to time
  • Approximately 24 1/2" clearance from the floor to the bottom of the platform, and 17.5" clearance form Platform deck to the JKU ceiling. 40” wide x 23” Deep inner dimensions.
bravelion
Austin, TX
2020 JLUR
Real Estate Investor
Is this a different product different than the "cargo basket" or the next generation of it?
AgentWolf
Tyler
Seattle, WA
2019 Jeep Wrangler Rubicon
Would it fit on a 2dr with the rear seats removed?
Vector Offroad
Vector Offroad
Utah U.S.A.
vectoroffroad.com
2018 Wrangler JLU
  • Thread starter
  • Thread Starter
  • #4
We have had a JL Platform available for 2 years. We just recently switched the product to brushed aluminum, which lowered the cost by $70, and reduced weight.
Vector Offroad
Vector Offroad
Utah U.S.A.
vectoroffroad.com
2018 Wrangler JLU
  • Thread starter
  • Thread Starter
  • #5
We will be releasing a 2 door Highland Platform by the end of March that works with the seats folded forward, or removed completely.
AgentWolf
Tyler
Seattle, WA
Was this released? I know stuffs crazy now. Just curious
Vector Offroad
Vector Offroad
Utah U.S.A.
vectoroffroad.com
2018 Wrangler JLU
  • Thread starter
  • Thread Starter
  • #9
We are shooting an install video on Monday, and the product will be on the website mid next week.
bravelion
Austin, TX
2020 JLUR
Yes, I have one installed. I made a video of it if you want to see it.
Edit: woops, I have the 4-door brushed aluminum, not the 2-door.
Vector Offroad
Vector Offroad
Utah U.S.A.
vectoroffroad.com
2018 Wrangler JLU
  • Thread starter
  • Thread Starter
  • #11
Steve,
please shoot us your video link to [email protected]. We would like to see it. Thank you
brain
brian
Milton, Georgia
www.unsinkablebriancork.com
2020 Wrangler JT (Gladiator) Mojave | Gobi
Business and Executive Coach
Before you order this product make note that it fits 2007-2018 Jeep Wrangler 2 door Hard Top or No Top only. That is right off of the website.
I made a mistake but blame myself for not reading more carefully before I placed my order.
The soft top and support brackets for the Vector Offroad Highland Platform both use the roll cage and need the same mounting location bracket holes.
NOTE: In the YouTube installation video () Keith does not mention this through the installation demonstration. When I called in to make and then verify my order (they were on back-order), I asked if this would work with the soft top. I was told yes. However, they failed to mention you can't use both at the same time.
So, while I'm sure the platform has it's uses, you will be limited to managing trips. Or, you will need a hardtop.
Allmoparparts.com
