- Jul 11, 2017
- Utah U.S.A.
- Website
- vectoroffroad.com
- 2018 Wrangler JLU
- Occupation
- Offroad Manufacturing
2 DOOR JL WRANGLER HIGHLAND PLATFORM $409.99
Installation video at the bottom of the link below.
https://vectoroffroad.com/collectio...products/jl-2-door-aluminum-highland-platform
Proudly Made in the U.S.A.
The Vector Offroad 2-Door Highland Platform practically doubles the usable space in the rear cargo area. It's a must for overlanders, campers, or serious grocery getters! This high strength solution is a perfect place to put gear for your next adventure.
The 2-Door Highland Platform provides the following benefits:
**Product images may display optional accessories, configurations, or finishes. The actual product may vary slightly from what is shown. If you have any questions regarding what is included with a product, please contact us.
***As with all of our products the 2-Door Highland Platform is designed for off-road use only, compatibility with OEM systems has not been formally tested.
- Mounting hole patterns cut into the platform for RotoPax Water/Fuel/Storage mounts. The platform can hold up to two 4-gallon RotoPax containers on the underside of the deck
- Light weight Aluminum Construction, weight tested to 230 lbs without failure
- Bolt-in installation, requires no permanent modifications to the vehicle.
- Standard finish - Brushed aluminum main Deck, with Powder Coat Hammer tone Gray accent components
- Multiple lashing points for straps and/or cargo nets.
- Approximately 25" clearance from the floor to the bottom of the platform, and 16” clearance form Platform deck to the JL hardtop ceiling. 40” wide x 23” Deep inner dimensions.
