Utilizing Under the Driver Seat?
tehfrr
WA
2019 Jeep Wrangler Moab
Has anyone had any success with the space under the driver's seat in the JL?
I want to install my air system manifold there and access it from the side with the drivers door open (operate ball valves, a couple different quick connect fittings, etc).
After a few hours of searching, the only thing that seems even remotely usable is the JL Audio amp rack.
https://www.jlaudio.com/products/sba-j-jlu-uar-stealthbox-accessories-99837
Almost $200 is a lot to pay when Im just looking for something to bolt a 3/8 manifold and some quick connect couplers down.
I dont have a shop so a metal shop DIY project is out. Any thoughts?
Thdoors
Dabber
Tucson, AZ
2020 JLU Rubicon, ‘06 Dodge 2500, ‘15 Honda Pilot
I can barely fir my hand under their to get the crumbs from the mess my kids make. Why not just install your air in the back or someplace else? I did my twin ARB behind the driver side rear passenger seat.
tehfrr
tehfrr
WA
  • Thread starter
  • Thread Starter
  • #3
Im using a Power Tank CO2 system. I want a manifold under one of the front seats, the drivers side is preferable.
I want a line going from the tank mounted on the roll bar, to a manifold under the drivers seat. From there, a line goes out through the clutch pedal opening and branches out to 4 high flow quick connect couplers, one by every wheel.
The manifold would have a drain ball valve (routed to outside) and a connect for a pressure gauge. It would also have a standard quick connect coupler and a schrader valve for connecting to other vehicles/systems.
Mainly the goal is to quickly air up/down all 4 tires at the same time without having the hood open and leaving the drivers seat little as possible.
zgrw
2021 JLUR
there is this from teraflex for half the price
https://teraflex.com/shop_items/55f8874205a25c5bb15066e8
40”JLURD
Ross
Southern California
2021 JL Unlimited Rubicon Diesel
Bad Mother Fucker
zgrw
2021 JLUR
sorry my bad, i thought it was jl
40”JLURD
Ross
Southern California
Bad Mother Fucker
If you’re dead set in that exact setup (sounds like quite the MacGyver project) you’re going to have to make it yourself or pay someone to do it for you.
A) If you have no shop and no fabrication skills you’re going to have to pay someone with both to do it for you.
B) If you have no shop but do have the fab skills I’d buy the tools and do it yourself wherever you park the Jeep. Even if it’s in the street. It’ll be cheaper and you keep the tools.
C) Put the manifold somewhere else.
There’s nothing like that out on the market that would fit under the seat.
I got the AAL remote kit for the cargo area. Meets my needs nicely and I did some customization to it.
SLK RCK
Jamestown, RI
2020 JLUR
Lucky Devil - Bright White Unlimited Rubicon EcoDiesel (JLURD) | 2018+ Jeep Wrangler Forums (JL / JLU) - Rubicon, Sahara, Sport, Unlimited - JLwranglerforums.com
Post #6. Lots of work and no easy solution, so it'll be either super expensive or non-existent due to cost vs value.
tehfrr
tehfrr
WA
  • Thread starter
  • Thread Starter
  • #9
Thanks for all the responses; appreciated.
The diesel Rubicon thread was pretty helpful.
I guess the plan is to see if I can fab something myself for < $200. If > $200 then I'll go with the amp rack.
Im pretty set on this config. My goal is to air up/down the absolute fastest possible. Id spend $100 on a part if it could shave off another 20 seconds from the total time. I'm trying to optimize every piece and part as much as I reasonably can.
The big motivator for this project is that I mostly do night wheeling. Out in the backcountry. Solo.
My least favorite part by far is sitting there crouched down messing with a tire while my hood is up with my Smittybilt 2781 on the ground telling the world "HEY SOMETHING INTERESTING IS HAPPENING HERE!!"
Thdoors
Dabber
Tucson, AZ
That’s quite the set up. Why do all that when you can use something like this. I have it and it works great. You could even make one for less and not have to do all that extra work. But, it’s your Jeep.
https://myoffroadradio.com/morrflate-off-road-4-tire-inflation-deflation-kit/
tehfrr
tehfrr
WA
  • Thread starter
  • Thread Starter
  • #11
That is the best off the shelf kit I have seen so far. Ive looked at it and talked with them on the phone.
They agreed the changes I had in mind made sense. They couldnt offer the config I wanted because only a few people would need/buy it; they asked me to send in a pic of it when Im done.
Edit: already built myself a 2 wheel setup like theirs only in 3/8 with high flow couplers, its what Im using now.
21Rubi
Jon
Tucson, Arizona
2021 Rubicon 2 door, Granite Crystal, 3.6 Auto
This is one cool mod idea. Would the marine world have something that would work, really don't have any info for you, just think this is a great mod. Good luck with getting it together. Keep posting your results as you piece it together.
MCJA
Matthew
Olympia, WA
2020 Wrangler Unlimited Rubicon EcoDiesel
My ARB installation was a lot more complicated than it needed to be. (Reference the "Lucky Devil" thread.) I did it that way because I wanted more convenience to fill all 4 tires at once, and I'm a wiring snob. (I like my wiring to look OE.)
If you want to install on-board air under your driver's seat, then ARB really makes everything you need. Their twin compressor system is more than capable of filling tires directly; no need for an air tank unless you want one. And their under-seat bracket includes everything you need to mount a pressure gauge and QD coupler.
You don't have to drill any holes, cut any wires, or anything like that. The whole kit just bolts in, and their wiring harness connects directly to the battery.
21Rubi
Jon
Tucson, Arizona
Matthew, that's an awesome air system. :like:
Diode Dynamics
