Pat Castiglione
- Jul 28, 2021
- Switzerland- AG
- 2019 JLUR 3.6 Auto
Hi everyone
Saw that a bunch of you in here run an Ursa Minor Campertop on your JLUs as well, and as there's not a whole lot out there on tzeh interwebz on these things, wanted to ask you what your experiences with it are.
Reason I'm asking is: I suspect/hope my UM might just be shimmed improperly up front.
1. Is yours truly waterproof?
Mine seems to leak just a teeny bit of water on the driver side rear door. There's often waterdrops to be found on top of the inside panel just beside the window. Was perfectly watertight with the factory softtop, even with a pressure washer at point blank, now it ain't.
=>If not: What did you use to seal up the top section or how did you adjust the shimming? How many shims did you end up putting in up front?
2. Is yours making creaking noises all the time?
Mine does it, also while on road/highway driving as well. We're smack dab in the middle of winter here in Switzerland, so a couple degrees below or above the freezing point. Maybe it's just normal, maybe again the thing is cracking under stress from being improperly shimmed.
Some additional Info/Clues:
Thx in advance and happy new year from the Alps!
PS: Pic 4 attention, will finish and document the build in spring I guess, before taking the rig to Morocco so god resp. the Missus wills it
- Of course it had to be put into a box for air freight (which f*in' sucked )
- Was installed in October when it was still a little warmer
- Got no extra windows in the UM's back
- Has 4 mounts on drivers side for the Awning (that's not yet mounted, so no stress there)
- Sealing foam that comes with it, we (=Outfitter and I) put under the rear of the Hardtop above the rear fenders.
- My '19 JLUR came "only" with the Factory Premium Soft top, no Hardtop. Don't think that makes any difference, but maybe we missed an additional seal that needs removing or sth...
- No, neither my girl nor myself are obese and could've caused any damage
