Urgent.. picture of wiring with aux switches needed
Jrbrannan
Bloomington, Il
2018 JLUR Ocean Blue 2008 Highlander Hybrid (previously several CJ-7, YJ, TJ, JK)
At dealer.. they are saying the wiring kit with aux switches.. pictures and details
Jrbrannan
Jrbrannan
Bloomington, Il
Torero
J. Diego
Illinois
JL Rubicon, FJ Cruiser, BMW Z3, F650,GL63 AMG, STI
Mine has the towing package and auc switches already but I was told there are white splices as well
What’s the question? If you got the switches already the only other thing is a plastic back with some connectors. Worth like $2. Nothing to it.
Jrbrannan
Jrbrannan
Bloomington, Il
Perfect! Good to know. Wanted to make sure I wasn't missing anything really important.
rogueknb
Kevin
Reno, NV
2018 JL Unlimited Sahara 4x4
Probably a dumb question, so I apologize, but need we all need to learn...how do you use these plastic connectors? Must be simple right?
Mojito Mojo
Doug
Apache Junction, AZ and North Mankato, MN
2018 Mojito Rubicon JLU, 2004 Corvette convertible, 2015 HD Road Glide, 2014 Indian Chief Vintage
They look like heat shrink tubes to cover the splice!
rogueknb
Kevin
Reno, NV
so basically just connect the two spliced ends in there and it will make a solid connection that is secure and "water-tight"...
Mojito Mojo
Doug
I’m no electrician, but slide one of the heat shrink tubes onto one of the wires, make the splice and slide the tube back over the connection. Then applying heat will shrink it and make it watertight.
DrPacman
Canada
2018 Wrangler JL
Found a great youtube video explaining the install of just this switch set... Search for "2018 Jeep Wrangler JL Gains More Accessory Options after a Mopar Auxiliary Switch System Install" by CJ Off-Road....
