Aonar
What type of timer do you use for your block heater?
Most suggestions that I have read state 2, 3, up to 4 hours max before you start wasting electricity - diminishing returns. Planning now before the need truly arises.
And NO, I am not debating the need for one
Thanks in advance!
When Should I Plug in My Engine Block Heater? (sherwoodford.ca)
Engine Block Heater: All You Need To Know | The Drive
EDIT: Read this suggestion but also looking for real life experience. "Programmable electronic timers can be found at most hardware and auto part stores and should be set to start engine block heaters four hours before you plan to start your car. Be sure to purchase a timer that is rated for 15 amps and is suitable for outdoor use."
Thanks in advance!
