Glscrambled
Sector,
How did you determine if you have the correct canbus? I installed it today, everything plugged in but my steering wheel controls aren’t working unless there is a setting in the unit itself. Also I did buy the backup camera adapter and I still just have a black screen when it goes into reverse. I spliced the red wire into the red power wire from the wiring harness and the ground into the ground. Seemed to make good connections. There was also a yellow wire that was labeled “bat” on the reversing adapter, should that also be going to power?
