californiajeeping
- Feb 1, 2019
- California
- JLUR
Note: The new and improved track bar has been available as of late February 2019. So it can be ordered now. Also, there is a reference to a 2 door in the Star case. It is referring to a 2 door TSB. This Star case applies to both a 2 and 4 door JL.
Star Case Number S1819000003 about steering problems was just updated on Feb 26, 2019. See screen grabs of the part about the new JL track bar with stiffer bushings and the new toe info below. The old track bar number was 68317849AA. The new track bar part number is 68394087AA.
And here is the toe spec info -
Here are just a few of the steering related threads.
https://www.jlwranglerforums.com/fo...ering-feels-like-it-has-play-and-drifts.3691/ (over 3,000 posts)
https://www.jlwranglerforums.com/forum/threads/steering-wheel-wobble.16577/
https://www.jlwranglerforums.com/fo...ring-is-good-tight-no-wander-no-wobble.21691/
Helpful links
Original version of this Star case from Oct 2018 - https://www.jlwranglerforums.com/fo...has-play-and-drifts.3691/page-142#post-426243
JL Torque Specs - https://www.jlwranglerforums.com/fo...rangler-jl-steering-related-components.18510/
JL Toe Specs - https://www.jlwranglerforums.com/fo...heel-alignment-specs-toe-caster-camber.17832/
FULL ISSUE BULLETIN BELOW:
PDF attached:
Helpful links
PDF attached:
