(update)New engine, it broke again a month later.
daniel5678
daniel5678
2021 jlu
1 on a buddies, 1 hilariously right after an engine install, then 2 other erroneous ones have come through my bay. But you have more issues than just the starter with yours.
I've always suspected that some wires were not connected properly or were damaged when the new engine was installed. If so, how does a dealer check?
IanNubbit
Ian
NJ
2022 JT 6MT Sport & 2023 JL 2 Door 6MT Sport
Jeep Dealer Tech
Diagnostic procedures. Duplicate concern, identify symptoms, pinpoint areas of concern. Find cause
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
Put a breaker bar on the crankshaft and it won’t turn over, then stop and call corporate because they’re about to put it on you.
daniel5678
daniel5678
2021 jlu
I'm not sure when they can do the inspection yet, but judging from the dealer's attitude, they don't want to be responsible for me anymore. Hope everything goes well.
Santana74
Jamie
Alabama
23 Wrangler Sahara Altitude 3.0l, 18 Jaguar F-Pace
Pretty sure that’s Scooby-Doo
It is......but it was the 1st thing I thought of. Had it stuck in my head all day.
Banjomule
Iowa
TJ, JK, JLU
Way off topic….. but you were right!
“Ruh roh Reorge” came before “ruh roh Raggy”
I just looked it up to confirm and it turns out both dogs were voiced by the same actor!
QUOTE="DaltonGang, post: 2534547, member: 24275"]
Ok guys. Just jump all over my ass for confusing the two cartoon dogs that are Ruffly(haha) 54 and 60 years old. I will try to do better. :(
[/QUOTE]
Ratbert
COS region, CO
AEV JL370 JLURD , AMG GLC43
Software Engineer
The most likely scenario here is no start due to nothing but the electrical issue and the smoking is 100% normal for the obstical.
I've done Hell's Revenge a few times and have never had the two Jeeps I've done it in smoke.
blessidsoul12
Jordan
Walla Walla, WA
2018 billet silver JLUR, 2019 chevy suburban
The current guess is indeed an electrical issue. When I saw the smoke coming out of the exhaust pipe, I immediately turned off the car. After I went to a safe place and tried to start it, it wouldn't start. The next day I tried the crank bolt (it can turn and works in both directions, but I didn't try to turn it once). Some people here think that the crank bolt needs to rotate a full circle to prove that it is not a hydraulic lock. So I am also a little nervous now about whether the engine will suffer fatal damage.
I'm confused about this part- did you see smoke, immediately turn off engine right then and there, after which it wouldn't start?
Or did you see smoke, immediately turn off the engine, restart it, move to a safer place, then turn it off again, after which it wouldn't start?
richk225
Rich
New Jersey
2021 392Rubicon XR 2017 Jeep Grand Cherokee
retired due to broken back
Who`s on first? Who watched the thanksgiving all time special
The March of the Wooden Soldiers
daniel5678
daniel5678
2021 jlu
When I see smoke, I turn off the engine immediately. The jeep stopped on the uphill slope, and I waited for my companion to use the winch to drag me to a safe place. When the winch was ready, I trun on (because I needed to turn the steering wheel and it couldn't start at this time). I forced it into N gear. After dragging the winch to a safe place, I tried trun on again but it still didn't work. But I have heard a "click" sound from the starter, but the motor does not turn.
Renegade
Zac
Signal Mountain, TN
‘20 JT
When I start the car, there is no power assist in the steering wheel, the battery is extremely low, and the fan is not working causing the water temperature to rise.
Finally checked the fuses and reinserted some of the loose fuses and the Jeep was fine again, but this has happened three times and I'm going to go to the dealer to have it checked thoroughly. Have any of you ever encountered this?
I’m having a hard time reconciling these two statements as referring to the same situation.
DaltonGang
Houston, Tx
[/QUOTE]
Ahhhh haaaaa. Redemption.
I thought Astro had said it before. But, it looks like the Scoob made the Ruh Roh saying more famous.
Alan_Hepburn
Alan
San Jose, Ca USA
2020 JT Sport S, 2022 JLU Sport S
I've seen many cams broken on V8s by the connecting rod getting smacked up into it.
Yup - I just got rid of an old Ford 390 that had a rod bolt problem: the rod ended up breaking the camshaft into 3 pieces!
