Under seat air coupler mounts
Jeepnutz
Don
Southern Oregon
2022 Jeep Wrangler Rubicon XR
Have a ARB dual compressor and under seat mount on order. I would like to have a air coupler on both sides so I'm looking for a coupler mounting solution that mounts beside the driver and passenger seat. Haven't had any luck with Google.
BullMoose1776
Bull
South Texas
Project Manager
I too am suffering from this condition. I am glad I found your post. Perhaps my comment will push this to the top for an enlightened Jeeper to see, and share with us.
MacombRoger
Roger
SE Michigan
2018 JLUR Ocean Blue
Solution Architect
BullMoose1776
Bull
South Texas
Project Manager
Well...yes and no. I'll have the compressor mounted on the passenger side with the ARB underseat mount. I'd like to have an additional hose run to the driver side, with an Air Hose Coupling on the driver side. I can source all the components for this, but have not yet found a mount for the air hose coupling.
I am not a metal worker so "fab one up yourself" is not an option for me.
MtCamper
Ken
NW Montana and Yuma Az
2018 jlUR White Rubi, 2018 GMC 3500 Duramax,
Retired Snowbird
I emailed them yesterday and got an immediate response. Looks like a company I'd do business with. My ARB is mounted behind the driver side passenger seat and they are putting together a kit for my application.
Jeepnutz
Jeepnutz
Don
Southern Oregon
I definitely like the ARB mount better than Innovative. Like you, all I'm looking for is a drivers side air coupler bracket.
813 Fabrication & Design
Rock Sponsor (Level 1)
Jeremy
Louisville, KY
2020 Jeep Gladiator / 2022 JLUXR
Terrymo
Terry
2023 JLURXR 3.6 ET
I have the ARB underseat mount on the passenger side. I used some thin flat aluminum stock from Home Depot. I unbolted the drivers seat and after drilling a hole in the aluminum, bolted the aluminum down using the front seat bolt. I used a rubber mallet to form the aluminum to the curve of the floor pan. Bolted an aluminum cb antenna mount to the flat stock.
More function than form compared to other options mentioned in this thread
CpT Papa
RUBICON 392
I did the ARB mount under the passenger seat with the manifold. From the manifold I ran a line through the console to the driver seat. I also ran wires so I can turn the compressor on/off from either side. I made the brackets and added the extra switches I needed.
Jeep Wrangler JL Under seat air coupler mounts 20221229_144237
Jeep Wrangler JL Under seat air coupler mounts 20221229_143741
