Under Hood Heat
ReimundKrohn
Ray
Alberta
2021 Wrangler Unlimited Islander Sting Grey
Side note, and I know this is kinda petty on my partā€¦ but this really ticks me off:
In my opinion that is a flat out marketing lie.
Was that particular to the JL Rubicon, or to the JL over the JK in general? The JL did add the functional side vents to all models for under hood air flowā€¦..
Jeep Wrangler JL Under Hood Heat D0666E99-A812-411A-A5FB-298E3D146D79
BDinTX
Dallas, Tx
Ours is the 2020 recon edition. Not sure if the sticker is specific to it. But all JL rubiconā€™s have the same NON heat reduction hood.
ReimundKrohn
Ray
Alberta
In that case, I donā€™t think youā€™re pickinā€™ nits. That there would be a flat out marketing lie.
Windshieldfarmer
Randy
Wichita, Ks
2015 JKU, 2020 JlU on order
I believe the Rubicon hood sits higher in the middle compared to non Rubicon models. I suspect this additional height keeps the engine bay modestly cooler at speed compared to the Sport. Just a thought. I donā€™t know if any car that is cool under the hoodā€¦.none that Iā€™ve owned.
Ronbo Ranger
Ron
Sierra Vista, Arizona
2021 JLU Wrangler Rubicon
I had been considering the functional hood vents the day I bought my JLUR.
But I held off so far for the reason mentioned in this thread, which has been a very good conversation. WATER šŸ’¦. I wonder if there's a way to channel water and still have functional hood vents. Now I have something to keep me up at night to think about now until this is solved.
johnnyj
Washington
Jeepless but still a fan.
I also modified my JLUR hood vents to be functional. Don't sweat a little rain with functional hood vents - everything in there is very well sealed up for some droplets of rain. I ran poison spider hood vents on all 3 of my TJ's in Washington rain for years - no issues. For real - the engine is 95% covered even with functional hood vents. The little bit that gets in there isn't going to hurt anything and at temperature is going to evaporate almost immediately.
SilverSurfer
Heinrich
South Africa
2020 JL Rubicon 3.6 8-speed Auto
It is completely normal for the engine bay to get hot, you should not be concerned about it.
Removing the hood liner is not a very good idea. If you do, heat from the engine bay will be absorbed by the metal of the hood putting the hood paint at risk of deteriorating over time. The hood liner serves a purpose (Sound and heat absorption).
But, we are Jeep owners and we loooove to fiddle, change, mod our Jeeps. Sometimes the urge to scratch where it does not itch overrides facts and our brains are fixated on modifying stuff that ain't broken šŸ˜
DHW
Atlanta
2018 Rubicon
Attorney
It's been done, see below. Although a lot of people say water isn't an issue.
https://www.jlwranglerforums.com/fo...or-your-rubicon-hood-diy-install-video.51897/
Kinda interested in the Valkyrie vents, but it seems like the individual vents are fixed and have to be bent to open/close. That I don't like.
Edit: Found one Valkyrie install video on YT and it confirms the vents are fixed and have to be bent to open. Also this guy didn't even cut the heatshield, citing water concerns, so his vents are no more useful than OEM.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
The higher underhood temps on the 2.0 is mostly due to the catalytic converter being located in between the engine and driver front fender liner.
The hood vents only have a small drain hole for water, which is directed to either side and drained behind the front fenders via the hood insulator pad. Having those vents wide open can possibly lead to a small chance of issues related to cold water washing over hot engine components. I've personally watched my coolant temp guage while driving around on hotter days in the upper 90's. I've yet to see the temps go past 200Ā°f, with an acceleration load on the engine. As soon as the throttle starts to relax to just maintain speed, the temp quickly drops at least several degrees.
Technically, they are correct as far as the hood being able to help with heat. It is aluminum, which is much better at absorbing and releasing heat than their stamped steel counterparts. Steel absorbs heat and just radiates it in all directions, thus blocking any further absorption.
@wiborcame up with a great solution, in my opinion. He opened up the factory vents and insulation pad, similar to what's already been pictured in this thread. But he used a specific material that allows heat to pass through, but doesn't allow water to drain unchecked over the top of the hot engine. If memory serves, he was able to maintain the factory drainage towards the fenders. Maybe he can chime in with his thoughts, now that some time has passed. We all know his jeep is no stranger to the elements.
Another benefit of the vents not being wide open is when fording water. The hood creates a bit of an air bubble that helps keep engine bay water levels in check. A fully vented hood would allow that same water level to rise higher when forming the same depths. It's why many say that it's best to keep a bit of momentum through deeper water. Enough to maintain the wake caused by the leading edge of the vehicle, that way the water doesn't get as big of a chance of infiltrating the intake tract.
DHW
Atlanta
2018 Rubicon
Attorney
IIRC he used Frogzskin.
Wabujitsu
Sarasota, FL
2021 JLUR, 2020 JLU Sahara
Retired US Army
HUGE ā€œlikeā€ to this post! My experience in Florida heat and water is the same. Another concern I have, which stops me from cutting the hood under my Rubicon hood vents, is a bow wave washing over the hood when entering a water crossing with speed and momentum. Besides, as previously stated, my 2.0T ALWAYS operates within normal temperature limits during blazing-hot Florida summer weather.
One_off
Palm Bay Florida
2021 Rubicon 2d Gecko Gr + 2021 Rubicon 2 White
Just because your engine water temp is not over temp does not mean all the other electronic components under the hood are not experiencing them.
The radiator and thermostat control the coolant Temps to that 190ish range. Trust me many parts are getting hotter than that!
I've got a new jeep coming in a couple weeks.
I'll use some temp probes I use for testing to compare before / after Temps when I cut holes in my rubicon vent and insulation.
JEEPIDON
Charlie
Forsyth, Missouri
2021 Rubicon, 2021 Gladiator Rubicon, 2013 Ram2500
Retired - Business Consultant
The hood pad has nothing to do with heat and paint, itā€™s a sound insulation pad. The paint gets hotter in the sun than from underneath.
on the JL it also serves to route vent water to the edge of the hood for disposal. Iā€™ve taken my pad and sent it to the recycler and cut the sides out of the vent
Jeep Wrangler JL Under Hood Heat 3F120A30-5F00-4835-BFAA-CA3784DCBD82
to release heat and attached a couple of hoses glued to plastic to route the water to the hood seals and out of the back of the engine compartment! Itā€™s been this way since January 2018! Check the photo.
SilverSurfer
Heinrich
South Africa
Sorry, you are incorrect. I do not want to school you on thermodynamics (Heat, Radiation, Conduction).
But, I will give you some clues; the difference between the paint on the hood and underneath the hood, the energy (Heat source) optimal operating temperature and the entropy of the material involved.
You are free to do what you feel is best for you, each to their own, but please do not claim your mod as scientific fact. It is nothing more than a cool non functional modification.
