Felix22369
- Jeff
- Aug 15, 2018
- Virginia Beach
- 2018 Wrangler JL Unlimited Rubicon
Has anyone had issues with the menu options at the bottom of the touchscreen not working? I just picked up my JL Unlimited Rubicon from the dealer (25 days from order to delivery!) and when I started it today the display was in the radio mode. All of the radio options worked fine (I could change presets, browse, etc), but none of the other menu options at the bottom of the screen worked (couldn't go into navigation mode, Apps, etc). The icons were highlighting as I was touching them and it was making the popping sounds as well as I would try to select something, but no actual change. I was in neutral at the time (manual transmission) and the display started to work normally when I shifted into first and began driving. When I got to my house I turned the Jeep off and restarted it with the same result. UConnect help line had me do a soft reset and it seems to be working ok now, but I wasn't sure if there was a setting somewhere I had somehow selected to disable those buttons. UConnect help had no clue. Again, the rest of the screen worked completely fine. One edit to this, the screen worked fine on pick up day. This anomaly happened on day 2 of ownership when leaving a store.
