Glen722
- Glen
- May 31, 2019
- Peoria, AZ
- '20 Rubicon JLU
Twin 2-Gallon Gasoline and Water RotoPax Set-up
Yours for just $200 (cost over $700)
Two (2) LOD RotoPax black texture mounting brackets with hardware that can bolt to any piece of 90° angled metal.
Two (2) RotoPax four-bolt Mounts with extensions and locks to accommodate stacked two-gallon RotoPax containers.
Two (2) red, Gen 2, 2-gallon RotoPax gasoline containers.
Two (2) white, Gen 2, 2-gallon RotoPax water containers.
GoWesty spigot for water RotoPax container.
Four (4) keys for the two RotoPax locks.
Note:
Note:
- I only used this set-up on one three-day overlanding trip.
- The white, 2-gallon, water RotoPax containers each have easy-to-use, self-venting, easy-pour water spouts.
- The water container spouts do not have gaskets (lost them)—you will need to replace the gaskets from RotoPax ($3.95 for three gaskets).
- The red, 2-gallon, gasoline RotoPax containers each have the easy-to-use, self-venting, easy-pour spouts and NOT the ECO spout that meets all EPA/C.A.R.B. requirements.
- You can purchase the hard-to-use ECO spout directly from RotoPax, if you want.
