Turn on rock lights temporarily when unlocking the doors?
aham23
A
Arizona
2021 JLU Rubicon
so the courtesy wire is the YELLOW, not the green/white as pictured above. I want them only on as part of the courtesy lighting.
21 JLUR with Aux Package.
Tacking this project soon. Much thanks all!
millerjl
Chuck
San Diego, CA
JLU Rubicon
Looking to do similar as well. Have KC cyclone rock kit on the way. Total is 2.52amps so not worried about running to footwell light for one source and aux 2 for other. Question, can I use a roadmaster 792 diode(2 inputs 1 output) or should I put a single line roadmaster 690 diode on each power input?
Will_Jeep
Will
Atlanta
Black 2108 JKU Sahara, Black 2016 Mercedes CLS400
Based on the backup light thread, and my garage knowledge of electronics, I think that you should be good with the 2 inputs 1 output version. In this instance you are using the diode to stop the electricity flowing back into the second power source, when the first is switched on, and you are only feeding one, common, device (rock lights).
millerjl
Chuck
San Diego, CA
JLU Rubicon
That’s what I am thinking. My only concern is a guess potentially there could be a time when power is on from aux 3 and the door is open giving power from the footwell lights. Will that burn up the diode or the lights?
Will_Jeep
Will
Atlanta
I don’t believe that it cause any issues, the lights will only draw what they need, amps. You still only have 12v going in, just from two sources, if one shuts off it will still have 12v from the other source, but the current draw remains the same.
Jeep Generation
Kevin
San Dimas CA
www.youtube.com
2018 JLU Rubicon, 2014 JK Willys, 1999 TJ Sport, 1966 CJ5-A
Got the Cyclones installed over the weekend. I put 8 under the Jeep.
4 on Each side. Front Bumper, Front Door, Rear Door, Rear Bumper.
Then I made a bracket out of ABS plastic and mounted a dual input diode and relay.
I can turn on the lights with my Trigger Switch System, or for momentary with the key fob courtesy light when unlocking.
I ran 4 circuits, 2 cyclones per. Front bumper, drive side, passenger side and rear bumper.
This is obviously way overkill than what is needed.
Icon Vehicle Dynamics
