Turn ANY Relay into a Bluetooth controlled relay with the TRIGGER ONE Solid-State Relay!
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
The first and only plug-and-play solid-state Bluetooth-enabled relay available! Our device is compact and waterproof, the TRIGGER ONE Bluetooth Solid State Relay handles up to 30 amps of current. The TRIGGER ONE works in new or existing installations to add wireless control as well as dimming and flashing to the attached accessory. Control existing vehicle light installations with either an iOS or Android mobile phone. This high-tech feature is a perfect way to keep your lights from draining your battery or other electronics to be ready when you are! Turn on a radio system from outside of the vehicle, add it to a trailer light circuit to activate an outside light from the grill or campfire, or connect it to your lights.
In addition to turning circuits on and off, the app allows activation of a flashing mode or brightness control of connected lighting.
Jeep Wrangler JL Turn ANY Relay into a Bluetooth controlled relay with the TRIGGER ONE Solid-State Relay! 4001-Trigger-ONE_03_1596x1596
  • Built-In Bluetooth Connectivity
  • Plugs into standard relay
  • Controlled via free TRIGGER ACS PLUS
  • Wireless dimming and flashing control
  • Controls lights, radio system, etc.
  • Activates flashing mode or brightness control
MORE INFO HERE:
https://www.oraclelights.com/products/trigger-one-bluetooth-solid-state-relay
ORACLElights
ORACLElights
Metairie, LA
The app settings provide momentary activation through a standard toggle on or off for individual circuits. Edit accessory names, view detailed instructions, set switch functions, and more from the comprehensive settings screen. To wirelessly connect to your device the TRIGGER ACS PLUS app it will ask you to pair and input PIN.
Jeep Wrangler JL Turn ANY Relay into a Bluetooth controlled relay with the TRIGGER ONE Solid-State Relay! 4001-Trigger-ONE_02_2000x2000_crop_center
Please Note: The TRIGGER ONE relay does not need to be used with any other TRIGGER accessories. This relay can simply be installed in place of a current standard relay and operated using the free TRIGGER PLUS app for iOS or Android mobile phones.
Add this to your TRIGGER 4 PLUS or 6 SHOOTER-equipped vehicles for additional wireless control!
ORACLE Terry
Terry
New Orleans, LA
Gladiator, Wrangler JL, Bronco, RAM TRX
Jeep Wrangler JL Turn ANY Relay into a Bluetooth controlled relay with the TRIGGER ONE Solid-State Relay! POTW-trigger1
Product of the Week: Trigger Wireless Control Systems
Ready to revolutionize how you control your vehicle’s lights and accessories? The Trigger Wireless Control Systems are here to simplify your setup and elevate your off-road experience.
Why Trigger is a Game-Changer:
🔹 Wireless Control: Manage your lights at the touch of a button—from wherever you are.
🔹 Plug-&-Play Installation: No complicated wiring; just an easy, hassle-free setup in minutes.
🔹 Adventure-Ready Durability: Designed to handle extreme weather, rough terrain, and heavy use.
🔹 Instant Response: Enjoy zero delay for precise, real-time lighting control.
🔹 Seamless Compatibility: Perfectly pairs with our LED light bars, spotlights, and more.
🔹 Tailored for Performance: Tested in the toughest conditions to ensure maximum reliability.
Whether you’re looking for a universal option or a vehicle-specific kit, Trigger has you covered. Our vehicle-specific kits come with everything you need for a perfect fit, making installation even easier.
🔗 Explore the lineup and take full control of your lighting setup today!
ORACLElights
ORACLElights
Metairie, LA
Looking to take control of your vehicle's accessories with ease? 💡 Check out our Trigger Controller Systems—wireless switching made simple! Learn more here!
