redelses
- May 29, 2018
- St George UT
- 2023 JLUR
$150 obo.
Tuffy security enclosure for 4 door JLU without subwoofer - though it can work with 2 door w/o rear seat, and Tuffy may now offer purchasing the single wall for the subwoofer models.
This secures everything inside when the rear door is shut. I have used this with a hard top and soft top and no top. I did add some carpeting to the top (combined with another piece to create as a sleeping platform), and I added a second bracket to each side to more securely connect to the rear tie down points (two tie downs per side).
Local/regional pickup, may be able to meet in areas nearby southwestern UT/southern NV.
NOTE From Tuffy website:
This enclosure will NOT work with the Wrangler 4xe model. Works with or without OEM hard or soft top. NOTE: 2-Door model back seat must be removed. The Security Deck Enclosure does NOT accommodate the OEM optional Alpine Rear Speaker. No drilling required. Mounting brackets are fastened to existing OEM mounting points in the vehicle floor.
