Tube Steps and Air Tanks
Yogi
Michael
Port Dover, Ontario, Canada
GM, P.Log, CITT, 310T
Is there any reason a person shouldn't, couldn't, or wouldn't use their tube steps/rock sliders as air reservoirs?
Seems to me that a couple of fittings, check valves and some Synflex air line that could be a fairly elegant solution to the problem of finding a place underneath to mount an air tank.
johnnyj
Washington
2020 JLU Rubicon, 2003 TJ Rubicon. Gone but not forgotten: 1998 Sport, 2002 Sport, 2006 LJ Rubicon
In theory - seems sound. In practice, I suppose it depends on how much pressure you're running, how hard you're wheeling, etc.
Designing your own with pressure in mind, creating a built for purpose set would probably be ideal so you could maximize capacity.
XJfanatic
Indianapolis
2020 JLU, 2016 Navigator L, 1990 Mustang, 1994 XJ
I have seen it done with 1/4 wall tubing. Pretty bomb proof.
Creeker
Jim
Hickory, NC
CJ-7, 2020 JLR
Step tubes would not hold a bunch air. Maybe a tire or two if one is running 35's or bigger.
In the back of the JLR is a 20 Lbs CO2 tank and it works well.
The C02 system is a combination of stuff bought on line for about $250, which is a lot cheaper than the ones sold as a 'complete' kit for over $700.
In theory, one CO2 tank should be able to fill four 37's bead locks about 12 times from ~10 PSI to ~25 PSI (i.e., good enough to get one home/lodge after wheeling or back to the trailer). The cost per tank of C02 is ~$20).
More info on the CO2 tank system is located at
https://www.jlwranglerforums.com/forum/threads/manual-2-door-rubicon-bikini-build.48532/page-7
Just my $0.015 worth.
LoganDzwon
Logan
SoFla
JLUR
I’ve seen it done with tub bumpers on older Jeeps. I can’t see why it wouldn’t work, but I’d be concerned I’d break them when rubbing.
Yogi
Yogi
Michael
Yes, that would be the downside, cracking one when you're playing in the rocks, but if you use a check valve on each it wouldn't deplete the entire system. I suppose if you were in such a situation that you broke or cracked both sides at the same time, you've probably got more to worry about than reserve air ... LOL
Terminex
Omaha
2019 JLUS
Fixing stupid....
could also do quick connects on each, giving you the option to remove one or both from the air path.
Reinen
Utah
2021 Jeep Wrangler JL Rubicon
You can do it, it was a more common DIY practice back in the day when nearly all aftermarket accessories were made of tubes. I've seen it done for both air and water. I always seriously questioned putting water in a steel tube, but people did it. Then again we also thought nothing of drinking from the garden hose.
I'll say one thing, you'll never wonder if you cracked a rock slider. That would be quite a show. :LOL:
Yogi
Yogi
Michael
I agree with you on the water ... that's just a recipe for disaster. Excessive rust and then potential contaminants if you need it for drinking water.
As for cracking one with 140 psi air pressure, it would just leak out. It's not like they would explode like shooting a 20lb propane tank with a .22-250 ... LOL
Reinen
Utah
Yeah, they wouldn't explode but they could make a heck of a noise. And if you're in a dusty place fugeddaboutit.
Now you got me thinking about storing propane in your rock sliders. That would be an awesome redneck Darwin move! Have the video camera handy. LOL
Yogi
Yogi
Michael
Superchips TrailDash 3
