californiajeeping
- Feb 1, 2019
- California
- JLUR
TSB 18-051-19 - Vehicle Stalls At Low Speeds And/Or Coming To A Stop / June 20, 2019
TSB NUMBER: 18-051-19
GROUP: 18 - Vehicle Performance
DATE: June 20, 2019
This bulletin is supplied as technical information only and is not an authorization for repair. No part of this publication may be reproduced, stored in a retrieval system, or transmitted, in any form or by any means, electronic, mechanical, photocopying, or otherwise, without written permission of FCA US LLC.
SUBJECT:
Flash: Powertrain Control Module (PCM) Updates
OVERVIEW:
This bulletin involves reprogramming the PCM with the latest available software.
MODELS:
2019 (JL) Jeep Wrangler
NOTE: This bulletin applies to vehicles within the following markets/countries: North America, EMEA, LATAM and APAC.
NOTE: This bulletin applies to vehicles built on or before April 10, 2019 (MDH 0410XX) equipped with a 3.6L V6 24V VVT Engine Up Grade I W/ESS (Sales Code ERC).
SYMPTOM/CONDITION:
Customers may experience the following:
• The vehicle stalls at low speeds and/or coming to a stop.
DIAGNOSIS:
Using a Scan Tool (wiTECH 2) with the appropriate Diagnostic Procedures available in DealerCONNECT/Service Library, verify all related systems are functioning as designed. If any Diagnostic Trouble Codes (DTCs) or symptom conditions, other than the ones listed above are present, record the issues on the repair order and repair as necessary before proceeding further with this bulletin.
If the customer describes the symptom/condition listed above, perform the Repair Procedure.
REPAIR PROCEDURE:
NOTE: Install a battery charger to ensure battery voltage does not drop below 13.2 volts. Do not allow the charging voltage to climb above 13.5 volts during the flash process.
NOTE: If this flash process is interrupted/aborted, the flash should be restarted.
Reimbursable within the provisions of the warranty.
18-051-19
-2-
TIME ALLOWANCE:
Labor Operation No:
18-19-06-9N
Description
Module, Powertrain Control (PCM) - Reprogram
(0 - Introduction)
Skill Category
1 - Engine Repair and Performance
Amount
0.2 Hrs.
NOTE: The expected completion time for the flash download portion of this procedure is approximately 6 minutes. Actual flash download times may be affected by vehicle connection and network capabilities.
FAILURE CODE:
The dealer must use failure code CC with this Service Bulletin.
CC
If the customer’s concern matches the SYMPTOM/CONDITION identified in the Service Bulletin, failure code CC is to be used.
When utilizing this failure code, the 3C’s (customer’s concern, cause and correction) must be provided for processing Service Bulletin flash/reprogramming conditions.
Customer Concern
DATE: June 20, 2019
SUBJECT:
OVERVIEW:
MODELS:
SYMPTOM/CONDITION:
DIAGNOSIS:
REPAIR PROCEDURE:
- Reprogram the PCM with the latest software. Detailed instructions for flashing control modules using the wiTECH Diagnostic Application are available by selecting the application’s “HELP” tab.
- Clear all DTCs that may have been set in any module due to reprogramming. The wiTECH application will automatically present all DTCs after the flash and allow them to be cleared.
18-051-19
-2-
TIME ALLOWANCE:
Labor Operation No:
18-19-06-9N
Description
(0 - Introduction)
Skill Category
Amount
0.2 Hrs.
FAILURE CODE:
CC
Customer Concern
