True Tire Size Database
Carlton
Chicago
Jeeps lots of jeeps
If you have been dealing with Jeeps or Trucks for awhile you are aware that tires do not measure up to what is stated on the sidewall or manufactures specs. We have all seen newbies complain that their 35 measures 33. Sorry, but it is normal for a tire to compress with a few thousand pounds sitting on it. The only brand I have seen measure taller is Interco.
One of the most common questions we see related to tires is: What do they measure? So I thought it would be great to make a database thread. There is a similar thread on [Banned Site] but I do not agree with their measurement process.
For your post please do the following:
1. State the brand & model of tire.
2. State the size listed on your tire
3. State your PSI
4. With a level across the top of your front passenger tire measure with a measuring tape. If you do not have a level, use a flat object. (A level is strongly preferred)
5. Post a picture and all above information.
View following post for example.
Carlton
Carlton
Chicago
Jeeps lots of jeeps
1. Milestar Patagonia MT
2. 40x13.50r17
3. 28 PSI
4. 39" tall
Jeep Wrangler JL True Tire Size Database 20190312_152532
blnewt
New Mexico
Just ask @cosine he knows!
Milestar Patagonia M/T E Load rating 295/70/17 (33.25" based on https://www.wheel-size.com/calc/ )
With OPs method (and yes, that is a level) and under load @ 30psi and being a front tire (which might be a bit shorter due to the heavier front weight).
32.75" so probably spot-on from what they should be :)
EDIT, measured rear tire and it's within 1/16" of the front so nothing significant.
Jeep Wrangler JL True Tire Size Database 100_4072
Jeep Wrangler JL True Tire Size Database 100_4071
aai
aai
somd
'18 JL 2.0 Rubicon : '20 JT 3.6 Overland
1. BFG KM3
2. 37 x 12.50 x 17
3. 31 psi
4. 35 3/4" tall
Jeep Wrangler JL True Tire Size Database IMG_3366
MyJlU
TJ
The Ocean State
2018 JKU Sport
Sr Product Line Researcher
four low
central New York
2018 JL
The PSI is going to cause discrepancies, ie,the tire will deform according to the tire pressure.
If you used the diameter of the tire off the vehicle, or the spare if it matches, you will get a more accurate figure
D60
CO
JL
This.
Measurements should be tire inflated and PSI stated (as well as wheel width) but should NOT be static loaded but rather unloaded.
THE BEST way to do this is a Pi tape. Failing that a cloth/fabric/nylon flexible tape and /3.1416.
Lufkin makes a nice Pi tape and easy to obtain via the interweb. Used the hell outta them when machining HDPE pipe liners 'cause nothing about plastics stays round. The cool thing with the Pi tape is you can pretty easily measure within 10 thou (and better) using just a tape
four low
central New York
2018 JL
This.
Yes, agree. Tire inflated, but not loaded, ie, off vehicle, or vehicle raised , say on a lift.
Carlton
Carlton
Chicago
Jeeps lots of jeeps
This.
Nobody cares what a tire measures off the jeep. They want to know what it measures under the jeep. There may be a slight variance due to PSI that is why it is included.
SilverRubi
Daniel
Kansas
2019 JLUR
I'm going to give this a bump. Interested to see what others are measuring their tires at on the Jeep. I just ordered a 3.5 Gamechanger and still debating tires. Would like to see how the KM3s, Toyo MTs, Patagonias, and Trail Grapplers compare to each other.
Martial Fartist
Christopher
Spring Hill, Florida
Been too long since the last post. It needs a bump.
Love reading these threads.
