Trouble getting LCA bolt in. Mopar 2” lift
Never3nuff
Chad
Fort Worth TX
'18 JLUR , '18 Jaguar F-Pace S
retired
I bought a Mopar 2” lift yesterday and installed it last night. The only problem I ran into is the lower control arm bolt at the axel. I was able to get the drivers side bolts in but I can’t get the hole to line up and get the bolt through on the passenger side. Any tips on how to get the hole to line up?
wesbowhunts
Wes
Anna, Tx
with vehicle suspended or on the ground?
nota4re
Southern California
2018 4-door Rubi
A lot of times you can use a common ratchet strap to pull the axle one way or another to get the hole to line up.
Spank
Pictures would be EXTREMELY helpful here.
Never3nuff
Never3nuff
Chad
Fort Worth TX
retired
  • Thread starter
  • Thread Starter
  • #5
I ended up doing that and using two jacks, one on each end of the axle. After about 20 minutes I was able to get the bolt through. The other side wasn't a problem because the shocks were off as well as both sway bar end links. That made moving the axle and getting the LCA to line up.
JASPER
Wayolife Sucks
Tucson
2018 JLU Rubicon and 2014 JK 2dr
use a jack to lift the axle or rachet straps.
richk225
Rich
New Jersey
2018 Jeep Wrangler JL Unlimited Rubicon. 2017 Jeep Grand Cherokee Overland
retired due to broken back
Glad you were able to get it back in, this info will definitely help out other forum members.
Probably too soon to tell, but how is the ride compared to stock?
Next Venture Motorsports
