Trimming with 40’s with 3 inch bump stops?
anotheraznguy
Tracy California
Mojito JLUR
Getting all my ducks in a row and was wondering where everyone is trimming when going 40’s. Looking to see if I can still get decent uptravel with 3 inch bumps.
I know that the rear of the rear quarter will need to be trimmed but what about the top or front of the rear?
for the fronts, do I need to chop the two brackets that used to hold the fender in?
Carlton
Chicago
Jeeps lots of jeeps
What size lift do you have?
I had 5 inches in front and 4.5 inches in the rear. Even with 3" bump stops I could easily tear the fronts off and rub in the rear.
I play in the mud and snow so it wasn't an issue. If you plan on rock crawling, I would remove all of the inners, or more likely, go with aftermarket flairs.
The back part of the front fender flare was easy to hit.
anotheraznguy
anotheraznguy
Tracy California
Mojito JLUR
I had 5 inches in front and 4.5 inches in the rear. Even with 3" bump stops I could easily tear the fronts off and rube in the rear.
I play in the mud and snow so it wasn't and issue. If you plan on rock crawling I would remove all of the inners, or more likely, go with aftermarket flairs.
lift height shouldn’t matter in terms of bumpstop since up travel is limited by bumpstops and hopefully not shocks. I am already running chopped rubicon fenders with artec inners.
were you rubbing anything metal in front or just plastic fender? And in the rear wheel was it just the back part of the fender? I still have a few weeks out before the axles arrive so I am just trying to see what else needs to be hacked off
cocaine_white
Will
Atlanta
2019 Wrangler Rubicon
Here you go. Slider was trimmed 2” front and rear. Rear pinch seam was trimmed on both sides of the rear tire.
see my insta page for more build info.
http://instagram.com/ecodiesel_jl
Jeep Wrangler JL Trimming with 40’s with 3 inch bump stops? 3EEA8CB3-BB1A-43CA-8883-2772DFE11770
Checked out your insta and that was helpful. I just got my AAL inners and gotta start trimming them up for mine. You have more pics of what you cut and how you modified the new inner fenders to get all the clearance?
