Tried to reset oil life and now jeep wont start
Mad Beach
Karl
JLU Sport S
Anybody have experience? Dealer can't look at it till Monday . Won't turn over and brake is now hard to floor. Batteries are new.
blnewt
New Mexico
2019 Jeep JL Sport S, 03 Toyota 4Runner, Infiniti G37, Toyota T100 (Retired 74 CJ-5, 80 CJ-7)
Disconnect battery for 30 seconds to reset ECU, hopefully that should help :)
Mad Beach
Mad Beach
Karl
JLU Sport S
  • Thread starter
  • Thread Starter
  • #3
Tried the battery disconnect idea, no help. Thanks
Spank
Did you disconnect both of them? Killing power to the main battery alone won't fully reset the Jeep.
Mad Beach
Mad Beach
Karl
JLU Sport S
  • Thread starter
  • Thread Starter
  • #5
Just top battery, not ESS . Think that could help ?
Mad Beach
Mad Beach
Karl
JLU Sport S
  • Thread starter
  • Thread Starter
  • #6
Well Spank, good thought, worked. Everything appears to have reset and started right up. Thanks !
Rhinebeck01
2018 2dr. Rubi
@Mad Beach
Which reset method were you using when you ran into the issue?
Oil Life Reset Method:
1. Without pushing the brake pedal, push and release the
ENGINE START/STOP button and place the ignition to
the ON/RUN position (do not start the engine).
2. Navigate to Oil Life submenu in vehicle Info in the
instrument cluster display.
3. Push and hold the OK button until the gauge resets to 100%.
Secondary Method For Oil Change Reset Procedure
2. Fully press the accelerator pedal, slowly, three times
within ten seconds.
3. Without pushing the brake pedal, push and release the
ENGINE START/STOP button once to return the ignition
to the OFF/LOCK position.
NOTE: If the indicator message illuminates when you
start the vehicle, the oil change indicator system did not
Spank
Excellent. Glad that fixed it... for now, anyway. Hopefully you don't run into that issue again.
Mad Beach
Mad Beach
Karl
JLU Sport S
  • Thread starter
  • Thread Starter
  • #9
@Mad Beach
within ten seconds.
I was the first method. After pulling the batteries cables, I was able to reset it with the dash menu.
Rhinebeck01
2018 2dr. Rubi
For years I did the pedal push way, Oil Life Reset with different JK's (4) I have owned.
With the JL, I have changed the oil 6 times now and how just gone to the Oil Life submenu and done it. Never had any issues doing this.
I have followed this forum very closely for over 2 years now and no one but you has had an issue such as yours. Weird.....................
Mad Beach
Mad Beach
Karl
JLU Sport S
  • Thread starter
  • Thread Starter
  • #11
Yes, more is going on. After getting it running, took for drive and middle of day headlights would not shut down on auto and check engine came on and off a couple times. Got back home and plugged in diagnostic, 7 error codes popped up. At dealer now, they say they see some voltage problems in systems but have yet to know what is going on.
_olllllllo_
William
The Wild Wild West in AZ
2019 Hellayella JLU Rubicon 6-speed
I am in the same boat. Never had an issue. I am in mechanical engineering and my IT guys always get mad at me because I just do things the way I think they should work. I just put it on Run (engine off) and hit ok to reset the oil life.
_olllllllo_
William
Hope they figure it out and it is an easy rectification.
Jim Marsh Chrysler Jeep
