Status
Not open for further replies.
fifteen52
Jon
Carson, CA
2018 Jeep Wrangler JLU Rubicon
We have just launched a new wheel for the JL community!
The new Traverse HD comes in hub centric fitment for the JL in 17x8.5 et0 5x5 fitment. Available in both Asphalt Black and Block Bronze.
All Traverse wheels come with our new Rock Ring to protect your valve stems against any pesky rock, while also draining water, mud, and other debris to keep your wheels properly balanced.
Available now at https://fifteen52.com/collections/c...verse-hd-asphalt-black?variant=15113774268482
Also available at the following fine retailers:
Quadratec - https://www.quadratec.com/search/fifteen52
Northridge 4x4 - https://www.northridge4x4.com/brand/fifteen52
All Terrain Outfitters
Rogue Offroad
Cypher
J
AZ
2020 Jeep Wrangler Unlimited Rubicon
Cybersecurity Leader
I really like those wheels. I had ordered a set of Icon Compression wheels but they were damaged in shipment. I was planning to wait for the JL Salta's but after seeing these I may like them more. Can you send me the specs such as weight etc? When will these be in stock to order?
GeoTracker
Geo
JLU Rubicon
Any chance you could provide some weight info? Thanks.
GregMG79
Greg
Houston, TX
2018 JLU Sport S 6spd
Construction Manager
I still can figure out the details on back spacing and offsets. Would a sport with mopar 2” lift work with these and 35x12.5 tires? Nice design!
swozey
Denver, CO
Just ordered Asphalt Black. Thanks! Great looking wheels
JeepSmash
San Diego
2019 Rubicon Unlimited
weight?
I'm on board for the bronze!
I’ll volunteer my sting gray for test fitting if you need. :giggle:
Cypher
J
AZ
weight?
I thought I was told about 29lbs per wheel in an email, but I can't find it to confirm. for how sturdy they look they are very light.
JeepSmash
San Diego
Yeah they look hefty. If it’s about 30 or below I’m in for a set.
fifteen52
fifteen52
Jon
Carson, CA
  • Thread starter
  • Thread Starter
  • #11
The Traverse HD comes in at 29 lbs per wheel. Our Turbomac HD is 26lbs per wheel and Analog HD is 27lbs per wheel. Proud to say we are part of the under 30 club! haha
fifteen52
fifteen52
Jon
Carson, CA
  • Thread starter
  • Thread Starter
  • #12
Yes they will work perfectly! I have the Mopar 2'' Lift and 37x12.5 on my JL so you will have even more room with the 35's :)
fifteen52
fifteen52
Jon
Carson, CA
  • Thread starter
  • Thread Starter
  • #13
Thanks for your support Mike! The black Traverse HD look great on your white JL!!
fifteen52
fifteen52
Jon
Carson, CA
  • Thread starter
  • Thread Starter
  • #14
What does the back space equate to in MM. compared to the stock
Hey Mark! So this will vary depending on which trim and wheel package came on your Wrangler, but most of the OEM wheels are a 17x7.5 et44.5 and our wheels are a 17x8.5 et0. So the outer edge of our wheels will poke about 56.7mm more than OEM. However the wheel faces still sit within the fender wells. The only time a wheel and tire set up will poke past the fenders is if an oversized tire is used, as you can see from our photos of my JL where my 37x12.5 tires stick slightly out past the fenders. However under full flex with the stock fenders and fender liners, they still tuck into the fenders quite nicely!
fifteen52
fifteen52
Jon
Carson, CA
  • Thread starter
  • Thread Starter
  • #15
weight?
The Traverse are 29lbs per wheel.
Do it! I originally really wanted the Sting Grey! Great color and looks awesome with the bronze.
Status
Rock Krawler
