beaups
2166 rpm is "closer to the proper torque band" for the diesel? Assuming your math is correct, an entirely usable RPM range is available for all 3 scenarios you provided, with the availability of lower RPMs with the stock gear set. I'm not saying regearing would necessarily make things worse (even though that is a possibility), but it is definitely not going to help make it better. This is a close-ratio 8 speed automatic; you aren't going to jump in a single gear from an engine speed that is too low to one that is too high.I know I'm going to do a bad job of explaining this so hopefully someone can help me out here. Increasing tire size without changing gearing moves the torque points that the factory programs in for stock tire sizes. These are ballpark and not exact number but a stock vehicle might be turning 1728 RPMs at 70 mph. A Jeep on 37s would be turning 1538 RPMs. But as the load increases that low RPM is going to lug the engine and make it downshift to 7th gear which jumps RPMs to 1971 RPMs to maintain that speed. But now assume you have an extra 2500 lbs behind you. Then it might further shift down to 6th gear which puts the RPMs at 2404 or even 5th gear which jumps the RPMs to 3149. That's going to increase the demand on the engine and increase the temps.
Now assume the same vehicle with 37s is geared to 4.10. 8th gear at 70 mph is 1691 RPMs and 7th is 2166. It's closer to the proper torque band. 4.56 gears would be 1881 RPMs in 8th and 2409 in 7th. With that gearing I doubt there is a need for the transmission to hunt down to 6th or 5th gear. Proper gearing keeps the vehicle in the proper torque band and the ultimately the RPMs and temps down. I hope that makes sense.
I got my numbers by using the gear ratio calculator on Grimmjeeper.com.
