Come on, you can admit it.
An immediate disconnect under load is better than a janky one (I paid for the janky one).
Yep. I’m old fashioned. All the gimmicks the whiz kids are able to program sure seem fun, but what about actually having skill? These “because we can” upgrades, like self-driving (self-guessing) cars, are dumbing down young drivers. Sort of like not knowing how to use a telephone or how to read a gas gauge.
It's a gimmick option to make the yuppy non off-roaders show there friends something they think is cool. The GMC Hummer EV has it as well. Think about if everyone used it on Black Bear pass instead of using a 3 point on the switchbacks. You'll have a horrible ruts in pretty much the same spot all the way down ruining the trail. You don't need it in sand, because most sand areas are wide open. Take your time, and use the right line or do a 3 point. Save the trails for the next guy.
That's debatable. Someone with sufficient skill can use throttle induced oversteer to turn a vehicle significantly sharper than it can be turned conventionally. It takes a hell of a lot of skill to do that in a controlled manner though.no amount of skill can make the vehicle turn sharper than it can conventionally.
Mine reconnects automatically also. (no tazer). I suspect that they all do.Not that that matters since mine reconnects once I go back under the speed (could be the tazer doing that though).
I suppose if you’re making you’re own trail, using a crutch would be handy. If you were following a trail, and you were a skillful driver, you wouldn’t need to do a pivot rotation. Skill is learned over time. Pushing a button to feel skillful is still just pushing a button.no amount of skill can make the vehicle turn sharper than it can conventionally.
Savage! Loldoing multiple point turns with several tons supported by 4 small surfaces is damaging to the trail as well. Using this can save trail damage especially since it can allow for smaller trails with smaller turn around areas.
just like a locker can damage or reduce damage to the trail… off-road equipment has its place.
if you really care about the environment, then why are you tearing it up with a Jeep? Get some hiking shoes and a Prius.
Nice theory, but that’s not how it will work IRL. People tear up trails when they use TTA. That’s what Ford has to repair the damage between runs during their Off Rodeos.doing multiple point turns with several tons supported by 4 small surfaces is damaging to the trail as well. Using this can save trail damage especially since it can allow for smaller trails with smaller turn around areas.
My first instinct was to call non-sense, but then I remembered being with my father (who spent many years in the racing industry, mostly as a head mechanic) when we were coming to a green light with a car stopped and waiting to make a left hand turn in front of us. My father didn't see the car and I didn't realize that he was unaware until the the last second when I called out. He did a perfect 90 degree skid assisted turn to the right with his side of the car right behind the other and us now facing and headed toward the curb, followed by a perfect 90 degrees back to the left where we then continued going straight as if nothing had happened... beyond him inquiring why I hadn't warned him sooner. Both turns where perfect and it looked like a lot of luck, but was likely a lot more. I never asked for the details and he likely wouldn't have shared anything overly useful. But yes, it is possible, you do have to be an expert, and someone that doesn't know what they're doing or isn't extremely lucky would likely just spin around and hit the car or something else uncontrollably. As this is a jeep forum, I should add that that was in a Fiero, which was a very low and fairly wide (for it's size) sporty (for the 80's) car.That's debatable. Someone with sufficient skill can use throttle induced oversteer to turn a vehicle significantly sharper than it can be turned conventionally. It takes a hell of a lot of skill to do that in a controlled manner though.
Yes, tazer or not, the sway bar automatically connects above a certain speed and then automatically disconnects again once you go below that particular speed. The only difference is the speed at which this occurs. This speed for a stock jeep is, I think, 18mph, and if you have a tazer connected, that speed increases to 30mph.Mine reconnects automatically also. (no tazer). I suspect that they all do.
true story. Not one time have I ever in all the years of off reading have I said to myself, “If only I could lock up the rear inside tire to make this turn. Might as well turn around and go back the way I came.” Not one time in 35 or so years of off roading.It's a gimmick.
It's a gimmick on the Bronco, and now it's a gimmick on the Jeep.
I'll be pulling a tiny military-style off road trailer this summer. I'm thinking that being able to turn significantly sharper would be much better than attempting a multi-point turn.true story. Not one time have I ever in all the years of off reading have I said to myself, “If only I could lock up the rear inside tire to make this turn. Might as well turn around and go back the way I came.” Not one time in 35 or so years of off roading.
