roaniecowpony
If you can't make an obstacle, push in your fuses and give it another try.
But should you go to a Rubicon? I'd say if I would only do it if the factory D44s, lockers and 4:1 transfer case were what I wanted in the end. The first thing that us Rubi owners worry about when crawling is breaking that FAD housing in the factory D44. So, Rubi owners spend thousands on UD44s or D60s.
If your desire is to go to 37s or higher, the Rubi D44s will give you the strength for confidence the axles will be less likely to break/twist axles. But they get to their limits quickly in the 39-40" tire range. So, for me, I'd really like to have a front axle without a FAD, but with hubs. That means a different set of wheels with larger hole pattern and bore, and different rear axles with a larger pattern. It's all a cascading series of changes.
If you do your own wrenching, a Rubicon transfer case and axles are relatively cheap compared to buying a new(er) Rubi. But it takes cash and work.
I didn't buy my 4 dr Rubicon to rock crawl/wheel. I bought it to hunt with my bird dogs. But, I came to a point where I wanted to do some activities with my old school friend before we run out of time (we're late 60s), and I decided to lift it, put 37s on it and do some of the BOH trails with him. But if I were to get a rig specifically to crawl/wheel, it'd be a 2 dr. A 2 dr can maneuver so much easier on the trail and it makes obstacles a lot easier. A 2 dr can do more difficult obstacles on smaller tires. That makes things cheaper right off.
