Track Bars, or not after Mopar 2" lift kit
tcon
Tim
Williamsburg,Virginia
2020 JLU Rubicon
I recently bought my first JEEP and joined the community. It's a 4door Rubicon with the 3.6 gas engine and auto transmission. The first mod I'm doing is the "Mopar 2 inch lift kit". This kit is the new redesigned Mopar lift kit. The original 2 inch Mopar lift kit had issues with the coil spring extensions and coil bowing.
After reading a ton of threads, and watching a bunch of You-Tube vids, I wanted to ask if anyone can tell me; "do I need to replace the front and rear track bars after doing this specific Mopar lift kit?" I will be keeping the stock wheels and tires on the vehicle for now.
D60
CO
JL
You can see how it looks and drives after, but I personally would absolutely replace them
Gadgettr1
Chip
Mass
2020 JLUR
college student
Jeep Wrangler JL Track Bars, or not after Mopar 2" lift kit Jeep_sideview
I'm in the same boat as you, just waiting for my kit to arrive. My plan is to go with the Mopar simulated beadlocks and 315/35' as of right now. Although 37's are tempting but probably more than I'll need.
cjljl2018
Jason
2022 JLUR 392 XR, 2021 JGCL Summit Reserve
I have the Mopar kit and replaced the front track bar and installed a relocation bracket in the rear. Cleaned it up nicely running 35's.
Buckleup
Cape Cod
2018 Wrangler Jl 2.0
I had the Mopar lift installed and it just did not handle very well after. I then took it to a shop that specializes in lifts and aftermarket doo dads and they added a new track bar and a rear track bar relocation bracket and centered the body over the axles. Now it drives like a charm.
Fire Burns
Fire
CA
2018 JLUR 3.6; 2006 Chrysler 300c SRT-8
Add em!
tcon
tcon
Tim
2020 JLU Rubicon
Thanks. I think I will do the lift first, then test drive and complete the track bar install myself.
Cthehentz
Kev
Vegas
Jeep JLU
I went with Rock Krawler front and rear, yes after you install the lift your front and rear will shift. To save yourself the aggravation do it all at once so you aren't chasing alignment issues.
tcon
tcon
Tim
2020 JLU Rubicon
Where did you purchase your RK's from?
Thanks!
Cthehentz
Kev
Vegas
Jeep JLU
Thanks!
[/https://www.northridge4x4.com/part/track-bars/rk06187-rock-krawler-adjustable-front-track-bar
4xFUN
Scottsdale AZ
2020 2-door Rubi. 2023 RAM TRX
What brand Track bar? Rock Krawler? or ...?
Lot's of good ones out there...I now have an all black Steer Smarts and could not be happier with it! I just I wish I had gone with it first time around as I tried another good brand but it did not play well with my top mount Fox 2.0 TS stabilizer...
Marin1812
Kevin
Plano Texas
Yes, replace both with adjustable track bars so you can re-center your axels. I went with Synergy’s track bars (pricey but very beefy, it will surprise you on how light the OEM track bar is)
