Towing a dirt bike
  1. trailchaser
    trailchaser Well-Known Member
    First Name:
    Javier
    Vehicle(s):
    2019 Moab
    May 16, 2019
    Haymarket, VA
    334
    Liked:
    79
    Recently I had a bit of a scare when putting too much tongue weight via kuat pivot rack and hitch basket all is well tho.
    But I need to find a way to tow around my dirt bike, there is an aluminum hitch rack that weights about 35lbs, the bike weights about 300-330 (debating which one I’ll pick up.
    Given that the tongue weight is 350, is this going to be too much?
    Is my only and safest option to buy a trailer? Really don’t have space for one.
    Thanks for the help.
  2. OP
    trailchaser
    First Name:
    Javier
    Vehicle(s):
    2019 Moab
    May 16, 2019
    Haymarket, VA
    334
    Liked:
    79
    Please help with any ideas, supposed to pick up the bike this weekend
  3. Adventure.AS
    Adventure.AS Well-Known Member
    Vehicle(s):
    2020 JLUR
    Jun 16, 2019
    Port Dover ON Canada
    265
    Liked:
    299
    Make sure you don't go over the rear axle and tire ratings
    If you want to put that much weight on the hitch, I would recommend getting it strengthened at a good hitch shop. They should be able to do it fairly inexpensively. I have had this done on my JK.
    You might also consider installing an Air Lift air suspension kit for the rear springs. This will help level the Jeep and assist the coil springs, but they will not do anything to lessen the load on the rear axle.
  4. DaltonGang
    DaltonGang Well-Known Member
    Vehicle(s):
    Sep 29, 2018
    Houston, Tx
    506
    Liked:
    541
    I would buy a trailer that puts the weight directly over the trailer axle/axles, to lessen the weight on the hitch.
    Trav.city likes this.
  5. OP
    trailchaser
    First Name:
    Javier
    Vehicle(s):
    2019 Moab
    May 16, 2019
    Haymarket, VA
    334
    Liked:
    79
    Limited space for a trailer unless I get storage unit....but then it’s another 150 a month
    I’ll only be doing this 5-6 a year.
  6. Ogre_FL
    Ogre_FL Well-Known Member
    Vehicle(s):
    2018 JL 2 Door Sport S
    Apr 19, 2019
    Cooks Bayou, FL
    131
    Liked:
    253
    #6 Aug 8, 2019
    There are a couple of threads down in the Towing & Trailer section where folks have used the Hitch racks for dirt/dual sports on the 4 doors.
    I happen to have a 2 door and a heavy dual sport/ADV bike (400#) so I use an aluminum folding/stand up type trailer.
    It does not take up too much space against the wall.
    Not the greatest shot, but thats it against the wall behind my white Tiger 1050.
  7. Jeremi
    Jeremi Member
    Vehicle(s):
    2007 JKUR 5.7VVT
    Mar 26, 2019
    SW Ontario
    Liked:
    I use a home built bike carrier to haul my DRZ400 around, the carrier is of significant weight(est 80lbs) as the DRZ is far from a featherweight. I do this with a 4” lifted JK on 37’s. It definitely feels different but I find it still comfortable to drive long distances. My advice is to lash the carrier side to side to take the “wobble” out of it, couldn’t hurt to instal trailer lighting on the carrier too as the bike will block much of the Jeep taillights. I say for it, it’s one of my favourite solo trip tools, limited fuel penalty great maneuverability.
  8. OP
    trailchaser
    First Name:
    Javier
    Vehicle(s):
    2019 Moab
    May 16, 2019
    Haymarket, VA
    334
    Liked:
    79
    Do you have any pics? What's the total weight you are putting on the tongue?
  9. OP
    trailchaser
    First Name:
    Javier
    Vehicle(s):
    2019 Moab
    May 16, 2019
    Haymarket, VA
    334
    Liked:
    79
    gave up on it, if i buy a trailer I'll have to pay for storage...I won't be going that often, maybe 10 times a year...ill be renting one from uhaul to start...if I start doing it more then I'll look at options
  10. Adventure.AS
    Vehicle(s):
    2020 JLUR
    Jun 16, 2019
    265
    Liked:
    299
    I hope you have a hardtop when you go to U-Haul as they won’t rent trailers to Jeeps with soft tops.
  11. mwilk012
    mwilk012 Well-Known Member
    Vehicle(s):
    2018 Ocean Blue JLU Rubicon
    Mar 10, 2018
    Virginia
    2,514
    Liked:
    1,984
    Occupation:
    USN
    Why not get a Gladiator?
  12. Dalingrin
    Dalingrin Well-Known Member
    Vehicle(s):
    Feb 19, 2019
    Arkansas
    119
    Liked:
    66
    By looking at only weight I'd say you're probably okay but I think there's more going on than just the weight. With a hitch rack I would worry that you'll have additional lever action that wouldn't be as apparent in a trailer. I think you're better off buying/renting a small trailer.
    trailchaser likes this.
  13. Trav.city
    Trav.city Well-Known Member
    First Name:
    Rich
    Vehicle(s):
    2018 Wrangler Unlimited JL Rubicon
    Aug 25, 2018
    Michigan
    312
    Liked:
    188
    Occupation:
    Sales Manager
    Garage Profiles:
    Not sure where you live, but a single space in an outdoor storage should only cost 30-40 a month. Just make sure you get a good hitch lock. If you get a small enclosed trailer you can even story your bike in it. Good luck.
  14. OP
    trailchaser
    First Name:
    Javier
    Vehicle(s):
    2019 Moab
    May 16, 2019
    Haymarket, VA
    334
    Liked:
    79
    Sky one touj
    Northern Virginia, everything is jacked up
  15. Ogre_FL
    Vehicle(s):
    Apr 19, 2019
    Cooks Bayou, FL
    131
    Liked:
    253
    Did a shake down run before a trip up to the mountains with my aluminum single rail folding/stand up trailer.
    As I expected, it was uneventful
    The jeep barely even feels it back there.
Loading...
Share This Page
