Adventure.AS
- Jun 16, 2019
- Port Dover ON Canada
- 2020 JLUR
I would suggest you check out Can-AmRV website. (https://www.canamrv.ca/towing-expertise/videos/) People come from all over North America to have their hitch work done by real experts.Hi all,
My head is literally spinning after reading so much information regarding tow capacities and various numbers. My wife and I have been searching for a trailer for a long time and finally came across one that checked all the boxes but was just barely outside of the official Wrangler limits. We had to drive a bit to see it and fell in love and negotiated a deal on it. We don't pick it up for a few days so have been using this time to double down on research specifically against this trailers specifications.
Our Wranglers tow ratings (2021 4XE Rubicon):
- 3500lbs GVWR capacity
- 350lbs hitch weight capacity
Our travel trailers specs: (1700BH model)
We have also purchased a weight distribution system and brake controller.
- 3280lbs UVW (dry)
- 4200lbs GVWR (fully loaded)
- 380lbs hitch weight
We will almost always be towing dry on long trips and with minimal cargo, most of which will be inside the jeep considering the tongue is already loaded at it's limit, but would balance the load as necessary. Obviously the loaded weight is well over the limit but this should only be when were hooked up at a campsite, not towing. The one number that has me concerned is the hitch weight, being 30lbs over the limit even when dry. If I understand correctly, the WDS will effectively increase the hitch weight capability, but shouldn't really think of it like that and just go by the official limit. The other thing I draw a bit of comfort from is knowing that the European version of our Jeeps are rated at being able to tow something like 5500lbs GVWR and 440lbs hitch weight (not exactly sure on those numbers but I know it's more than our US versions). Again, not using that as an excuse to be able to buy a larger trailer here, still trying to stay within spec at all costs, but being 30lbs over on hitch weight is driving me nuts. I know there are others on this forum who are towing much larger trailers and have had a lot of success. We just want to be safe and feel completely confident when towing this trailer behind the jeep.
Looking for folks to either tell me I'm crazy for towing this close to the limits or to tell me I'm totally fine. Any advice is welcome!
