laueddy
I've read many posts about towing, and there are many reasons stated on why the JLU has such low towing capacity, but don't necessary find them all very convincing.
The JLU is rated with tow capacity of up to 3500 lbs. There are many theories and here is my summary, and let me know that you think?
The Short wheelbase: Many suggested that it's the short wheelbase. Yes, this is no F150, but let's compare that to the Durango which is rated 6200 lbs in towing capacity. (The SRT is rated 8700 lbs w/ the same 119.8" WB)
2018 JLU Rubicon 3.6 vs 2018 Durango 3.6
WB: 118.4" vs 119.8"
Track: 64.4" vs 63.9"(F)/64.1"(R)
Weight: 4390 lbs vs 4985 lbs
Height: 73.6" vs 70.9"
PS: Tow capacity of the Jeep LWB (LJ)? is rated to tow 3500 lbs. (WB 103.4", Curb Weight 3694 Lbs) https://www.autoblog.com/buy/2006-Jeep-Wrangler-Unlimited__2dr_4x4_LWB/specs/
Tongue weight & hitch strength. In terms of Towing Capacity/Tongue Weight, the UK version is rated 4400lbs/440lbs. AU is even higher rated 2495kg with speed limit set to 60mph max. I know sway would be an issue when traveling at higher speed, but it seems the hitch isn't the limiting factor. Do we have someone with the knowledge on how much additional stress is put on the Jeep Hitch when travel at speed faster than 60mph with a tow?
We know the engine isn't the limiting factor or the Wrangler diesel would have be able to tow more.
So, other factor which may affect the tow capacity are:
Brakes: So, we can solve this by upgrading the brakes (Powerstop Brakes?)
Suspensions: (Better shocks?)
Frame: Consider the amount of stress with the bigger tires and off road, I just don't think that's a limiting factor.
Tires: Maybe tires with better grip would improve tow capability?
If this is marketing related, I have a feeling the next Wrangler will have a higher tow capacity to complete with the Ford Bronco. What do you think?
