Status
Not open for further replies.
JeepinGeorge
Londonderry, NH
1998 Wrangler Sahara
Any guesses as to payload and towing capacity?
My best guess would put it somewhere around 4000 combined. 500-1000 in the bed, 2500-3500 towing with up to 500 trailer tongue weight. At least that's what I'm hoping for because hey wouldn't it be cool to pull a trailer with your modded Wrangler on it to the trails with your Wrangler truck ?
Dackel
San Clemente
2014 JKU, Ram 1500
Might be tough though? JKU's towing capacity is 3500 lbs. JKU Sahara weighs about 4400 lbs. So towing capacity has to go up by almost 1000 lbs.
Hope they do it though... I'm just imagining a JT in front and JK in back. :involve:
JeepinGeorge
JeepinGeorge
Londonderry, NH
Got the idea wheels turning did it?
Campbell
Oceanside
Challenger
Keep in mind towing capacities in US are always understated for liability reasons and to make FCA lawyers sleep better at night.
The JKU towing capacity is listed as 3500 lbs in US but guess what it is in Australia? 4400 lbs! And it's the same car made in the same plant in Toledo.
So real world towing capacity will be much higher than what's actually published for the US JT pickup.
Spank
This number needs to go up significantly if the JT is going to compete with other trucks. 4,000lbs is depressingly pathetic.
Vegas_Sirk
Boise, ID
2013 JKU
2017 Toyota Tacoma Towing Capacity: 3,500 lbs
2017 Chevy Colorado Towing Capacity: 3,500 - 7,000 lbs
2017 Honda Ridgeliine Towing Capacity: 3,500 - 5,000 lbs
My guess is it will be on par with those, the diesel will get similar to the diesel in the Colorado around 7,000 lbs and the base V6 around 3,500 lbs. The Grand Cherokee with the Eco Diesel is at 7,500lbs
Spank
The Tacoma can pull up to 6,400lbs if it gets the tow package. And seeing as how virtually all V6 mid-size trucks average a towing capacity of 6-7k, the JT should at least match the competition.
Otto
Otto
WA
Wrangler Sport (JK)
Impressive # for a midsize pickup. WHat's in the towing package that almost doubles the Tacoma's towing capacity?
noitsbrad
Pacific Northwest
2015 JKU
The 3,500 lb capacity for the 2017 Tacoma is for the 4 cylinder option. The V6 with Toyota's "Tow Package" looks to be between 6,400-6,800 lbs. All this info was taken from the 2017 Tacoma brochure
Otto
Otto
WA
Wrangler Sport (JK)
So "tow package" includes different engine. Same transmission?
Vegas_Sirk
Boise, ID
2013 JKU
6,800 lbs with the V6 is impressive. I bet it wouldn't be fun to tow 6,800 lbs with the V6 though. That motor isnt much better then the wrangler's 6
JTman
Denver
Wrangler JT to come
I'm surprised that 278hp / 265 lb-ft can tow 6800 lbs. But gives me hope that the Jeep JT can achieve 6000+ lbs tow capacity too.
JeepinOutfitters
Lewisville, TX
www.jeepinoutfitters.com
1995 XJ, 2016 JKUR Hard Rock
Outfitting Jeeps for adventures.
The XJ was rated for 5,000lbs towing and it was only putting out 190hp / 235 lb-ft with the 4.0L I6. The Pentastar puts out 285hp / 260 lb-ft. With a full frame, heavier duty axles and powertrain, plus longer wheelbase and bigger brakes, it still baffles me as to why the JKU is only rated at 3500 lbs towing (or even 4400lbs in AUS). A Grand Cherokee with the same engine (and the 8sp transmission) can tow up to 6200 lbs.
Given that the Tacoma will be the JT's primary competition I'd be really surprised if Jeep doesn't at least come spitting distance of the Taco's towing and payload capacity.
The Great Grape Ape
Canadian Rockies
2015 JKU AspenX 5spd , 2015 JK Sport 6spd
The Export Wranglers with tow package come with the Big Brake kits, so that's one aspect regarding the AUS vs USA.
However as I mentioned in the diesel/transmission thread, it's not the power of the Engine that's the limiting factor. When asked if the AEV Hemi conversion would improve towing, they replied that it was still limited by other components.
As I mentioned in the other thread the Pentastar in the RAM 1500 can tow much more, 7,650 lbs (quad/8spd/4x2) giving back 200lbs for 4x4, and that's using the 3.55 axle ratio, not even the 3.92 that the EcoDiesel can be equipped with. With the same configuartion with the 3.55 axle the EcoDiesel is rated for 8050lbs, only 400 lbs more than the Pentastar. Who knows what the Pentastar could do on the same 3.92 axle/setup of the EcoDiesel.
So it's definitely more than just the engine holding things back.
GI Jimmy
TN
Tacoma, Waiting on next Wrangler
So sounds like it's the axle ratio that's makes the biggest difference in tow capacity and the reason the JK tow capacity is so low because of its high 3.21 axle ratio?
Any idea how much more higher tow capacity the JK would have if it used the Ram's 3.55 or the even higher 3.73 that JK owners often upgrade to?
Status
