Torque Values For Jeep JL Wrangler
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
ABS
Part|Nm | ft. lbs. | in. lbs. | Comments
Anti-lock Brake System (ABS) Bolt | 8 Nm | - | 70 in. lbs. |
Front Brake Lines at Hydraulic Control Unit | 23 Nm | 17 ft. lbs | - |
Front Wheel Speed Sensors Bolt | 7 Nm | 5 ft. lbs. | 62 in. lbs. |
Front Wheel Speed Sensor Routing Bracket Bolt | 29 Nm | 21 ft. lbs. | - |
Hydraulic Control Unit (HCU) Bracket Bolts | 9 Nm | 7 ft. lbs. | 80 in. lbs. |
Primary Brake Lines to Hydraulic Control Unit | 25 Nm | 18 ft. lbs. | - |
Rear Wheel Speed Sensors Bolt | 11 Nm | 8 ft. lbs. | 97 in. lbs. |
Rear Brake Lines to Hydraulic Control Unit | 23 Nm | 17 ft. lbs. | - |
Secondary Brake Lines to Hydraulic Control Unit | 23 Nm | 17 ft. lbs. | -|
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
AXLE - FRONT - M186
Part |Nm |ft. lbs .| in. lbs. | Comments
Half Shaft Nut | 136 Nm | 100 ft. lbs. | - |
Bearing Cap Bolts| 108 Nm | 80 ft. lbs. | - |
Differential Cover Bolts | First Pass - 16 Nm, Second Pass - 41 Nm | First Pass - 12 ft. lbs, Second Pass - 30 ft. lbs. | - | Do not reuse these fasteners. If removed, a NEW fastener must be installed and tightened to specifications.
Drain Plug | 34 Nm | 25 ft. lbs. | - |
Fill Plug | 34 Nm | 25 ft. lbs. | - |
Hub Bearing Bolts | 100 Nm | 74 ft. lbs | - |
Pinion Nut | 217 Nm | 160 ft. lbs. | - | Do not reuse these fasteners. If removed, a NEW fastener must be installed and tightened to specifications.
Ring Gear Bolts | 108 Nm | 80 ft. lbs. | - | Do not reuse these fasteners. If removed, a NEW fastener must be installed and tightened to specifications.
Front Axle Disconnect Skid Plate Bolts | 42 Nm | 31 ft. lbs | - |
Front Axle Disconnect Bolts | 18 Nm | 13 ft. lbs. | - | Do not reuse these fasteners. If removed, a NEW fastener must be installed and tightened to specifications.
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
AXLE - FRONT - M210
Axle Shaft Nut | 136 Nm | 100 ft. lbs. | - | Do not reuse these fasteners. If removed, a NEW fastener must be installed and tightened to specifications.
Bearing Cap Bolts | 108 Nm | 80 ft. lbs. | - |
Differential Cover Bolts | 41 Nm | 30 ft. lbs | - |
Differential Drain Plug | 34 Nm | 25 ft. lbs. | - |
Differential Fill Plug | 34 Nm | 25 ft. lbs. | - |
Pinion Flange Nut | 217 Nm | 160 ft. lbs. | - | Do not reuse these fasteners. If removed, a NEW fastener must be installed and tightened to specifications.
Ring Gear Bolts | 136 Nm | 100 ft. lbs. | - | Do not reuse these fasteners. If removed, a NEW fastener must be installed and tightened to specifications.
Front Axle Disconnect Skid Plate Bolts | 42 Nm | 31 ft. lbs. | - |
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
AXLE - REAR - M200
Axle retainer nuts | 80 | 59 | - |
Bearing cap bolts | 65 | 48 | - |
Differential cover bolts | 41 | 30 | - | Do NOT reuse these fasteners. If removed, a NEW fastener MUST be installed and tightened to specifications.
Drain plug | 34 | 25 | - |
Fill plug | 34 | 25 | - |
Pinion nut | 240-550 | 177-406 | - | Do NOT reuse these fasteners. If removed, a NEW fastener MUST be installed and tightened to specifications.
Ring gear bolts | 180-240 | 133-177 | - | Do NOT reuse these fasteners. If removed, a NEW fastener MUST be installed and tightened to specifications.
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
BODY
A-pillar grab handle bolts | 9 Nm | - | 80 in. lbs. |
B-pillar grab handle bolts | 9 Nm | - | 80 in. lbs. |
Backlite to hardtop bolts | 11 Nm | 8 ft. lbs. | - |
Body isolator front: body nuts | 48 Nm | 35 ft. lbs. | - |
Body isolator front: frame nuts | 66 Nm | 49 ft. lbs. | - | Turn an additional 155°
Body isolator A-pillar bolt | 125 Nm | 92 ft. lbs. | - |
Body isolator B-pillar bolt: body bolt | 125 Nm | 92 ft. lbs | - |
Body isolator B-pillar bolt: frame nuts | 48 Nm | 35 ft. lbs. | - |
Body isolator C-pillar bolt: body bolt | 125 Nm | 92 ft. lbs. | - |
Body isolator C-pillar bolt: frame nuts | 48 Nm | 35 ft. lbs. |-|
Body isolator D-pillar bolt: body bolt | 125 Nm | 92 ft. lbs. | - |
Body isolator D-pillar bolt: frame nuts | 48 Nm | 35 ft. lbs. | - |
Cargo rail trim screws | 7 Nm | - | 62 in. lbs. |
Cowl panel end bolts | 9 Nm | - | 80 in. lbs. |
Cowl side panel-to-body- bolts | 8 Nm | - | 71 in. lbs. |
Door armrest bolts | 8 Nm | - | 71 in. lbs. |
Door carrier plate to door bolts | 7 Nm | - | 62 in. lbs. |
Door check strap to door nuts | 11 Nm | 8 ft. lbs. | - |
Door check strap to pillar bolt | 9 Nm | - | 80 in. lbs. |
Door exterior handle support bracket screw | 1.9 Nm | - | 17 in. lbs. |
Door exterior handle screw | 1.9 Nm | - | 17 in. lbs. |
Door glass to regulator bolts | 14 Nm | 10 ft. lbs. | - |
Door hinge pivot nuts | 6 Nm | - | 53 in. lbs. |
Door hinge to door bolts | 28 Nm | 21 ft. lbs. | - |
Door hinge to pillar bolts | 48 Nm | 35 ft. lbs. | - |
Door interior handle bolt | 7 Nm | - | 62 in. lbs. |
Door latch bolts | 7 Nm | - | 62 in. lbs. |
Door striker bolts | 26 Nm | 19 ft. lbs. | - |
Exterior mirror fasteners | 9 Nm | - | 80 in. lbs. |
Fender to body bolts | 9 Nm | - | 80 in. lbs. |
Folding top lift assist to sport bar bolts | 13.5 Nm | 10 ft. lbs. | - |
Front fender flare bolts | 7 Nm | - | 62 in. lbs. |
Front seat bolts | 50 Nm | 37 ft. lbs. | - |
Front seat back bolts | 73 Nm | 54 ft. lbs. | - |
Hard top to body bolts | 12 Nm | 9 ft. lbs. | - |
Hard top to B-pillar bolts | 12 Nm | 9 ft. lbs. | - |
Hard top front receiver bracket bolts | 12 Nm | 9 ft. lbs. | - |
Hood catch bracket to hood nuts | 7 Nm | - | 62 in. lbs. |
Hood catch to fender nuts | 15 Nm | 11 ft. lbs | - |
Hood hinge to body bolts | 25 Nm | 18 ft. lbs | - |
Hood hinge to hood bolts | 17 Nm | 13 ft. lbs. | - |
Hood pop up spring bolt | 10 Nm | - | 89 in. lbs. |
Hood prop rod bolts | 8 Nm | - | 71 in. lbs. |
Hood safety hook to hood bolts | 10 Nm | - | 89 in. lbs. |
Instrument panel carrier bolts | 12 Nm | 9 ft. lbs. | - |
Instrument panel cowl bolts | 11 Nm | 8 ft. lbs. | - |
Instrument panel dash bolts | 6 Nm | - | 53 in. lbs. |
Instrument panel to center floor nut | 10 Nm | - | 89 in. lbs. |
Radiator crossmember bolts | 11 Nm | 8 ft. lbs. | - |
Radiator crossmember brace bolts | 9 Nm | - | 80 in. lbs |
Rear lift arm bolt | - | - | - |
Rearview mirror to header bolts | 8 Nm | - | 71 in. lbs. |
Rock rail / side steps to body bolts | 28 Nm | 21 ft. lbs. | - |
Rock rail / side steps rail nuts | 15 Nm | 11 ft. lbs. | - |
Second row seat armrest bolt | 25 Nm | 18 ft. lbs. | - |
Second row seat back bolts | 45 Nm | 33 ft. lbs. | - |
Second row seat bolts | 64 Nm | 47 ft. lbs. | - |
Second row seat headrest bolts: bench seat | 8 Nm | - | 71 in. lbs. |
Second row seat headrest bolts: split seat | 8 Nm | - | 71 in. lbs. |
Second row seat feet bolts | 64 Nm | 47 ft. lbs. | - |
Second row seat nuts | 70 Nm | 52 ft. lbs. | - |
Second row seat pivot bolts | 45 Nm | 33 ft. lbs. | - |
Second row seat pivot nuts | 19 Nm | 14 ft. lbs. | - |
Soft top lift assist bolts | - | - | - |
Soft top linkage bolts | 12 Nm | 9 ft. lbs. | - | Apply thread locking compound.
Swing gate check strap to tailgate bolt | 11 Nm | 8 ft. lbs. | - |
Swing gate exterior handle screw | 1.9 Nm | - | 17 in. lbs. |
Swing gate hinge to body bolts | 28 Nm | 21 ft. lbs. | - |
Swing gate hinge to tailgate bolts | 48 Nm | 35 fb. lbs. | - |
Swing gate latch bolts | 5 Nm | - | 44 in. lbs. |
Swing gate stabilizer bolts | 10 Nm | - | 89 in. lbs. |
Swing gate striker bolts | 26 Nm | 19 ft. lbs. | - |
Windshield frame to header bolts | 16.5 Nm | 12 ft. lbs. | - |
Windshield hinge to cowl frame bolts | 30 Nm | 22 ft. lbs. | - |
Windshield hinge to windshield frame bolts | 25 Nm | 18 ft. lbs. | - |
Windshield wiper | 25 Nm | 18 ft. lbs. | - |
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
BRAKES
Brake booster nuts | 24 Nm | 18 ft. lbs | - |
Brake rotor splash shield bolts | 11 Nm | 8 ft. lbs | 93 in. lbs. |
Electric vacuum pump bolts | 8 Nm | 6 ft. lbs. | 71 in. lbs. |
Front brake hose to axle | 11 Nm | 8 ft. lbs. | 97 in. lbs. |
Front brake hose upper bolt | 13 Nm | 10 ft. lbs. | 115 in. lbs. |
Front brake caliper bolts | 37 Nm | 27 ft. lbs. | - |
Front caliper brake hose banjo bolt | 35 Nm | 26 ft. lbs. | - |
Front brake line to hose nut | 20 Nm | 15 ft. lbs. | - |
Front brake hose to frame bolt | 11 Nm | 8 ft. lbs. | - |
Front caliper adapter bolt | 200 Nm | 148 ft. lbs. | - |
Front rotor screw | 20 Nm | 15 ft. lbs. | 177 in. lbs. |
Front brake hose bracket nut | 18 Nm | 13 ft. lbs. | - |
Front caliper bleed screw | 10 Nm | 7 ft. lbs. | 89 in. lbs. |
Master cylinder brake lines | 23 Nm | 17 ft. lbs. | 168 in. lbs. |
Master cylinder nuts | 18 Nm | 13 ft. lbs. | 159 in. lbs. |
Primary hydraulic control unit [HCU] brake line nut | 25 Nm | 18 ft. lbs. | - |
Parking brake lever nuts | 25 Nm | 19 ft. lbs | - |
Pedal sled nuts | 24 Nm | 18 ft. lbs. | - |
Reaction bracket to support bracket | 19 Nm | 14 ft. lbs. | - |
Rear brake caliper bleed screw | 10 Nm | 7 ft. lbs. | 89 in. lbs. |
Rear brake caliper bolts | 37 Nm | 27 ft. lbs. | - |
Rear brake rotor screw | 20 Nm | 15 ft. lbs. | 177 in. lbs. |
Rear brake hose to axle | 22 Nm | 16 ft. lbs. | - |
Rear brake caliper adapter bolt | 100 Nm | 74 ft. lbs. | - |
Rear brake hose axle bolt | 22 Nm | 16 ft. lbs. | - |
Rear brake line to hose nut | 20 Nm | 15 ft. lbs. | - |
Rear right brake line tube to tube connection | 18 Nm | 13 ft. lbs. | - |
Rear brake caliper hose banjo bolt | 35 Nm | 26 ft. lbs. | - |
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
BUMPERS & FRAME
Front bumper support bracket nuts | 20 | 15 | - |
Front bumper to frame nuts | 90 | 66 | - |
Hitch to frame bolts | 90 | 66 | - |
Rear bumper to end cap bracket nuts | 25 | 18 | - |
Rear bumper to frame bolts | 90 | 66 | - |
Rear bumper to L-bracket fasteners | 25 | 18 | - |
Rear bumper wing bracket nuts | 35 | 26 | - |
Skid plate fuel tank to trans crossmember | 65 | 48 | - |
Skid plate to frame | 65 | 48 | - |
Tow hook bolts | 127 | 94 | - |
Transfer case skid plate bolts | 75 | 55 | - |
Transmission crossmember to bracket bolts/nuts | 175 | 129 | - |
Transmission crossmember to frame bolts (right hand side) | 70 | 52 | - |
Transmission crossmember to skid plate | 75 | 55 | - |
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
COOLING
A/C condenser bolts | 5 | - | 45 |
Belt tensioner bolt | 50 | 37 | - |
Block heater bolt | 12 | 9 | - |
Coolant crossover bolts | 11 | 8 | - |
Cooling fan bolts | 8 | 71 | - |
Coolant recovery bottle bolts | 10 | - | 89 |
Left idler pulley bolts | 25 | 18 | - |
Center idler pulley bracket M8 bolt | 25 | 18 | - |
Center idler pulley bracket M10 bolt | 55 | 41 | - |
Center idler pulley bracket to generator bolts | 24 | 18 | - |
Center idler pulley bolt | 50 | 37 | - |
Radiator brace bolt | 10 | - | 89 |
Radiator to body bolts | 11 | 8 | - |
Right idler pulley bracket bolts | 24 | 18 | - |
Right idler pulley bolt | 25 | 18 | - |
Thermostat housing bolts | 10 | - | 89 |
Water pump M6 bolts | 11 | 8 | - |
Water pump M8 bolts | 23 | 17 | - |
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
CLUTCH
3.6L Pressure plate to flywheel bolts | 30 Nm | 22 ft. lbs. | - | Do NOT reuse these fasteners. If removed, a NEW fastener MUST be installed and tightened to specs.
Clutch master cylinder nuts | 17 Nm | 13 ft. lbs. | - |
Clutch pedal bracket to dash | 20 Nm | 15 ft. lbs. | - |
Clutch pipe to transmission bolts | 18 Nm | 13 ft. lbs. | - |
Clutch slave cylinder | 10 Nm | - | 89 ft. lbs. |
Flywheel to crankshaft bolts | 52 Nm | 38 ft. lbs. | - | Do NOT reuse these fasteners. If removed, a NEW fastener MUST be installed and tightened to specs.
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
EGR (Exhaust Gas Recirculation)
EGR blocker plate to cylinder head | 23 | 17 | - |
EGR cooler bracket nuts | 23 | 17 | - |
EGR cooler tube to cylinder head | 23 | 17 | - |
EGR temperature sensor | 37 | 27 | - |
EGR tube to EGR valve | 10 | 7 | - |
EGR tube to EGR cooler | 10 | 7 | - |
EGR valve to intake manifold nuts | 10 | 7 | - |
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
ENGINE
ENGINE BLOCK
Connecting rod cap bolts | 20+ 90° Turn | 15+ 90° Turn | - | Do NOT reuse these fasteners. If removed, a NEW fastener MUST be installed and tightened to specs.
Crankshaft target wheel to counterweight bolts | 11 | 8 | - | Do NOT reuse these fasteners. If removed, a NEW fastener MUST be installed and tightened to specs.
Crankshaft outer main bearing cap and windage tray M8 bolts | 11 | 8 | - |
Crankshaft inner main bearing cap M11 bolts | 21+ 90° Turn | 15+ 90° Turn | - |
Crankshaft side main bearing cap (tie bolt) M8 bolts | 30 | 22 | - |
Crankshaft position (CKP) sensor to engine block M6 bolt | 12 | 9 | - |
Engine block ground strap | 20 | 15 | - |
Engine block heater - M6 bolt | 12 | 9 | - |
Lower oil pan to upper oil pan - M6 bolts | 11 | 8 | - |
Upper oil pan to engine block M8 bolts | 23 | 17 | - |
Oil cooler to oil filter housing screws | 12 | - | 106 |
Upper oil pan to rear seal retainer M6 bolts | 10 | - | 89 |
Oil pan drain plug | 27 | 20 | - |
Oil pressure sensor to oil filter housing | 20 | - | 177 |
Piston oil cooler jet to engine block bolt | 6 | - | 53 |
Oil filter housing/oil cooler to engine block M6 bolts | 12 | - | 106 |
Oil filter housing cap | 25 | 18 | - |
Oil pump to engine block M6 bolts | 12 | - | 106 |
Oil level indicator to cylinder head bolt | 18 | 13 | - |
Oil pump sprocket M8 bolt | 26 | 18 | - |
Oil pump pick up tube bracket to windage tray M6 bolt | 12 | - | 106 |
Oil pump pick up tube to oil pump M6 bolt | 12 | - | 106 |
CYLINDER HEAD
Camshaft bearing cap | 10 | - | 89 |
Camshaft chain tensioner (primary) bolt | 12 | 9 | - |
Camshaft chain guide (primary) bolt | 12 | 9 | - |
Camshaft chain idler sprocket bolt | 26 | 19 | - |
Camshaft chain LH tensioner (secondary) bolt | 12 | 9 | - |
Camshaft chain LH guide (secondary) bolt | 12 | 9 | - |
Camshaft chain RH tensioner (secondary) bolt | 12 | 9 | - |
Camshaft chain RH guide (secondary) bolt | 12 | 9 | - |
Camshaft position (CMP) sensor to cylinder head bolt | 9 | - | 80 |
Cylinder head coolant pipe plug | 35 | 26 | - | Do NOT reuse these fasteners. If removed, a NEW fastener MUST be installed and tightened to specs.
Cylinder head oil restrictor M8 plug | 18 | 13 | - |
Cylinder head cover M6 bolts | 12 | 9 | - |
Catalytic converter to cylinder head M8 bolts | 23 | 17 | - |
Fuel rail to lower intake manifold M6 bolts | 7 | - | 62 |
Heater hoses to cylinder head cover bracket | 8 | - | 71 |
Intake manifold (upper) M6 bolts | 10 | - | 89 |
Intake manifold (lower) M6 bolts | 9 | - | 80 |
Intake manifold support bracket lower M8 bolt | 25 | 18 | - |
Intake manifold support bracket upper nuts | 10 | 7 | - |
Oil control valve/cam phaser bolt - exhaust | 150 | 118 | - |
Oil control valve/cam phaser bolt - intake | 30 + 45° Turn | 22 + 45° Turn | - |
Oil temperature sensor to cylinder head | 11 | 8 | - | Do NOT reuse these fasteners. If removed, a NEW fastener MUST be installed and tightened to specs.
Spark plug to cylinder head | 18 | 13 | - |
Throttle body support bracket bolt | 10 | 7 | - |
Throttle body support bracket bolt to front cover | 10 | 7 | - |
Variable valve timing solenoid to cylinder head cover bolt | 4 | - | 35 |
Variable valve lift solenoid bolt | 10 | 7 | - |
Wire harness retainer bracket to LH cylinder head bolts | 10 | 7 | - |
FRONT ENGINE
Coolant crossover housing to engine timing cover M6 bolts | 12 | 9 | - |
Engine timing cover M6 bolts | 12 | 9 | - |
Engine timing cover M8 bolt | 25 | 18 | - |
Engine timing cover M10 bolts | 55 | 41 | - |
Thermostat housing to coolant crossover M6 bolts | 12 | 9 | - |
Vibration damper M16 bolt | 40 +105° Turn | 30 + 105° Turn | - |
Water pump to engine timing cover M6 bolts | 12 | 9 | - |
Water pump to engine timing cover M8 bolt | 25 | 18 | - |
Water pump to engine timing cover M10 bolt | 55 | 41 | - |
REAR ENGINE
Flexplate to crankshaft bolts | 94 | 69 | - | Do NOT reuse these fasteners. If removed, a NEW fastener MUST be installed and tightened to specifications
Rear crankshaft oil seal retainer bolts | 12 | 9 | - |
Torque converter to flexplate bolts | 42 | 31 | - | Do NOT reuse these fasteners. If removed, a NEW fastener MUST be installed and tightened to specifications
Trans to engine block bolts | 50 | 37 | - |
Trans to upper oil pan bolts | 50 | 37 | - |
ENGINE MOUNTING
Left engine mount isolator to engine block bolts | 55 | 41 | - |
Left engine mount isolator to frame nuts | 115 | 85 | - |
Left engine mount heat shield nuts | 8 | - | 71 |
Rear mount isolator to transmission bolts | 54 | 40 | - |
Rear mount isolator to transmission crossmember nuts | 175 | 129 | - |
Right engine mount isolator to engine block bolts | 55 | 41 | - |
Right engine mount isolator to frame nut | 115 | 85 | - |
Transmission crossmember to left side frame nuts | 120 | 89 | - |
Transmission crossmember to right side frame bolts | 72 | 53 | - |
Transmission pan crossmember to frame bolts | 75 | 55 | - |
Transmission pan crossmember to transmission crossmember bolt | 75 | 55 | - |
MISCELLANEOUS
Air inlet hose band clamps | 5 | - | 44 |
Air cleaner housing to side rail | 7 | - | 62 |
Air cleaner lid bolts | 4 | - | 35 |
Air cleaner resonator to shroud bolts | 5 | - | 44 |
Engine lift bracket | 21 | 15 | - |
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
EVAP
Vapor canister to vehicle bolts | 6 | 4 | - |
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
EXHAUST
Catalytic converter to cylinder head bolts | 24 | 18 | - |
Exhaust Y-Pipe to catalytic converter flange bolts | 18 | 13 | - |
Front exhaust isolator bolts | 30 | 22 | - |
Exhaust resonator clamp bolt | 30 | 22 | - |
Heat shield nuts | 3 | - | 27 |
Muffler clamp nut | 55 | 41 | - |
Muffler exhaust isolator bolts | 25 | 18 | - |
JAY
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
FUEL DELIVERY
Fuel rail to intake manifold bolts | 7 | - | 62 |
Fuel tank skid plate bolts | 95 | 70 | - |
Fuel fill tube clamp | 4 | - | 35 |
Fuel pump control module to rear crossmember bolts | 6 | - | 53 |
Fuel tank filler tube mounting bracket bolts | 6 | - | 53 |
