skrubi12
- May 30, 2018
- New Market, MD
- 2018 JLUR
anyone know the factory torque specs on the steering stabilizer?
Try thisanyone know the factory torque specs on the steering stabilizer?
You interpreted that a little wrong:STEERING LINKAGE
Part |Nm |ft. lbs. | in. lbs. | Comments
Drag link inner nut (at pitman arm) | 105 | 77 | - |
Drag link outer nut (at steering knuckle) | 64 | 47 | - |
Drag link adjuster clamp | 46 | 34 | - |
Tie rod end nut (at steering knuckle) | 64 | 47 | - |
Tie rod end adjuster clamp | 46 | 34 | - |
Steering damper bolt (at axle) | 80 | 59 | - |
Steering damper nut (at tie rod) | 80 | 59 | - |
Steering damper bracket nut | 75 | 55 | - |
59 in. lbs ----->>>> 80 ft. lbs (if I understand well)
You are correct. You're going to set your metric torque wrench to 80 Nm.OkT hanks a lot, It's true ..I hadn't really seen the first column .. (I was seeing Part number instead of Newton meter )
but still not clear .. in this case Nm is above the 80 and the Ft. lbs. is 59
Isn't it?
This is from the FSM.Can I revive an old thread? There's no way the little 13mm bolts going from the bracket into the axle are 55 ft lbs.
We’re talking about the steering stabilizer bracket that goes into the axle with 3 bolts right? They’re so tiny. You’d snap them or strip the bolt head trying to do 55 ft lbs on those.This is from the FSM.
