Torque Spec for Xtreme Recon wheels
Loudone
Northwest Suburbs Chicago
22 Wrangler Unlimited Rubicon
Field Service Manager
Is the torque spec of 130 ft-lb correct for the Xtreme Recon wheels?
Yellow Cake Kid
Jeep
The torque spec is for the studs. The torque is a proxy measurement that correlates with the clamping force of the stud and nut assembly to ensure the security of the wheel to hub connection.
Some wheel materials compress more than others when clamped upon, so follow up inspection and retightening will be required more or less often depending on the wheel choice.
The JK used the 12mm studs, and the JL uses the 14mm studs. The 14mm studs provide the potential for greater maximum clamping force, but also require more torque to begin stretching the stud at the lower portion of the range of the potential for clamping force, so the relatively high 130 pounds per foot with clean dry threads is prescribed.
Capt. Don
Don
Puerto Rico
2022 Jeep Wrangler Unlimited High Tide
US Merchant Marine Master, 100T
Good answer, thank you. And how about the torque specification for the bead lock ring?
77RRAD
Ron
Las Vegas
2019 JLUR
Bead lock ring should be 15 ft lbs then re torque to 20 ft lbs
Capt. Don
Don
Puerto Rico
Thank you. I had trouble finding that information. Good to know.
