Tommy From TFL Took His Willys Offroad
aldo98229
Aldo
Bellingham, WA
Market Research
Looks like although this is his personal vehicle, he will be using it to create content for work...and to help himself write it off in his taxes.
Notorious
North Texas
2000 TJ Sahara
Do people want to see that man playing with his short, red and black at the tip Willy’s offroad?
aldo98229
Aldo
Bellingham, WA
Market Research
I have a somewhat similar setup to Tommy's in that my Sahara has a 2.72:1 transfer case, a rear Trac-Lok limited slip, and no swaybar disconnect. Granted, I also have a Mopar lift and 35-inch tires.
Nevertheless, last weekend I went off-roading with some friends to a remote area in the Cariboo Region of British Columbia. On a 10-point scale, the level of difficulty was in the 6-8 range. The Wrangler handled it with flying colors. No ifs or buts; it simply got through everything I threw at it without issue.
At one point we climbed a steep 1.5-mile long, 20%-grade trail of loose rock to a mountain top, with 5 adults and 2 dogs on board. I engaged into 4L and kept a steady 3 MPH: the Jeep got to the top without complaint.
I am very happy with this thing.
You can faintly see the trail to the top of the mountain in the distance
Jeep Wrangler JL Tommy From TFL Took His Willys Offroad 1626284714678
MrMischief
JL Rubicon
I spent way too long confused by this. "Okay I know ifs is independent front suspension, what the hell is buts? brake lock, no ..... back up traction, no..."
I think I need more time in the real world.
aldo98229
Aldo
Bellingham, WA
Market Research
:LOL:
Yup. By comparison, the 4WD system on my friends' two Mercedes-Benz Sprinters hesitated every time the going got tough.
Mercedes relies too much on electronics to get you through difficult spots. The trouble is, when traction goes down to near zero, so does engine power.
Jeep is smart in that as soon as you engage 4L, it turns off all electronic controls.
eck
Apex NC
2018 JLU MOAB HellaYella
Basically the same here, it's amazing what it can do. The brake lock differential is surprisingly effective in situations where you lift a tire and would otherwise want lockers (although it's not a substitute).
Manually disconnecting the sway bar makes such a big difference, too! Just a bit annoying trying to get it back in line to reconnect. I carry a bottle jack to help get everything lined up again.
aldo98229
Aldo
Bellingham, WA
Market Research
It is so refreshing to see a video about a $30,000 Wrangler being used out in the wild, as opposed to a $60,000 Rubicon --or a non-existent Ford Bronco-- on a controlled course.
WAOLIFE
Adrian & Josie
So Cal
2019 JLUM - 3.6L - Sky Touch & 2015 WK2O - 3.6L - IG: @wa0life
Fiddler of Parts
Ask trailrecon followers, and you will have your answer.
rallydefault
PA
'18 JLU Sport S
It was a cool video. I like watching their offroad stuff when they just put some cool shots together with some chill music in the background. Colorado looks absolutely stunning and I really hope I can get out there some day.
aldo98229
Aldo
Bellingham, WA
Market Research
I have JKS FlexConnect swaybar links with quick release, but I was too lazy to disconnect them.
The FlexConnect adds a few degrees of articulation even without disconnecting.
  • Like
Reactions: eck
Spank
Did he openly admit to paying 35k for a Jeep? Doesn’t he know how to haggle? Shouldn’t have paid a penny more than 25k
If you can find a new JL for $25k, I'll eat the corn out of your poop.
