To replace track bar or not to
homebrew
paul
Washington
18 Wrangler JL Rubicon
Currently running a 2.5 rough country lift on my rubi. Initially I had the alignment checked and it was still within specs( near the end of them however) it wandered pretty bad. I added adjustable lca’s and that helped a lot. No DW at all. Wondering is there any benifit to be had by installing an adjustable track bar other than centering the axle? I’m shopping right now and have one in my basket, wondering if it’s worth it or money better spent somewhere else?
OffRoadWarehouse
San Diego, CA
www.offroadwarehouse.com
2018 Jeep JL
Jeep, Shock, Suspension, and Export Specialist
If your track bar wears out and you plan to go bigger, then definitely throw on an adjustable trackbar, but at your height, and even with wheeling, the trackbar wont be necessary.
mdallas
Martin
New England
BMW X5 M50i, BMW X5 40i, JLU Sahara
Get some massive ones like RK . Recentering is one thing but the whole feel of the steering and ride will be better. These thing weigh about 5x the OEM track bars.
plex
Cincinnati, OH
Weekend keyboard mechanic and beer drinker
Just keep in mind, with the Wrangler design you will never get "true" centered body and axle relationship, regardless how you adjust your track bar.
On the other hand, most aftermarket track bar come with better bushings which will help mitigate some steering issues but not all.
drdriller
Houston
2019 jl
Can you just bolt on a new trackbar like a steering stabilizer?
plex
Cincinnati, OH
Yes you can, although some aftermarket track bars require a little bit of drilling to enlarge the mounting bracket on the axle side.
