To Kill 12v Power to the JL/JLU
FatBoy01
NY
2014 Wrangler Sahara; 2001 Harley FatBoy; 2018 Wrangler Rubicon JL (Ordered)
Retired @ 55
  • Thread starter
  • Banned
  • #1
You DO want to kill 12v power before working on any electrical connections on your JL/JLU!
To kill 12v power coming from the JL/JLU's Main and ESS batteries you need to disconnect as per the picture below. One nut is a 10mm nut and the other two, are 13mm nuts.
FatBoy01
FatBoy01
NY
Retired @ 55
  • Thread starter
  • Banned
  • #3
What page in the manual is this?
This info is not in the manual. 1st pic is one I doctored up. The second pic is from JL install instr. for the Aux kit I believe.
I promise ...;) this is the way you kill all 12v power to the JL/JLU.
mgroeger
Hurricane, UT
I believe you :)
Just was curious, there are others on the forums saying the same thing. I need to disconnect the battery tonight. Yesterday I went through a hi pressure car wash and now the compass shows -- instead of N, E, etc...
Hopefully that will fix it.
JeepDrvr2018
Montgomery
2013 Jeep Wrangler Unlimited Sahara
Retired Master Certified RV Tech
Well that is something, don't thin my 2013 JK Sahara has all those. Is the battery under the battery the one for start/stop?
mgroeger
Hurricane, UT
Yes, my understanding is it's the start/stop battery although it may control other things as well.
I'm not sure about the JKs, this info above in the pic is only for the JLs. People were just disconnecting the battery when they were doing electrical work like adding switches, lights, etc... not realizing they had not truly killed the power to the car.
mgroeger
Hurricane, UT
Well this was interesting. Last night I took the three ground terminals off and it did indeed kill everything in the Jeep. The lead that goes to the fender that is connected to the 10mm bolt seems to be "live". By that I mean when reconnecting it the thing sparked and I could here a relay or something clicking in the fuse box next to it.
Other than that everything powered back up and all presets on radio were still there.
JIMBOX
JAMES
FERNLEY NV
RETIRED
Thanx FatBoy01--very good info --
JIMBO
mgroeger
Hurricane, UT
Twice I've had to disconnect the three negative battery terminals. Each time terminal #2 (from your pic) sparks like heck when you touch it back to the bolt to thread it on. I can here a clicking noise coming from the black box right next to it.
Have you experienced that?
FatBoy01
FatBoy01
NY
Retired @ 55
@mgroeger
I do not have a JL yet.
Normal to see this ....... is what I can tell per posts here, a YouTube video I saw and a tech I asked at the stealership a couple of weeks ago.
mgroeger
Hurricane, UT
OK, thanks for letting me know. If you have the link to the video I'd like to see it. I figured it had to be normal even though I'd never seen a negative terminal do that before.
"Stealership"... LOL
FatBoy01
FatBoy01
NY
Retired @ 55
Additional info that you might be interested in..
You can have a fully charged Main battery and if the ESS battery is either dead or disconnected, the JL will not start, even though the main battery is fully charged. On the other hand, if the main battery is missing or dead the ESS battery can start the JL/JLU.
If you wanted to isolate the positive side, disconnect N1 & N2 in the power distribution box.
N1-Main battery, N-2 ESS battery.
FireWire
Ontario, Canada
2015 Ram EcoDiesel, Polaris RZR900, 2018 JL Sport S
interesting stuff regarding the JL electrical system. In the firefighting world, it has been common practice to disconnect the battery in the case of a vehicle crash. This is to prevent an air bag going off while a patient is being attended to and to prevent cutting into live wires. Hybrids are a whole different animal to deal with. Now ESS cars are added to the mix. I will be doing some research on procedures for dealing with these vehicles. Especially because we have one.
ALRUI
Arnold
Murphy, NC
2018 JLU Sahara, 2003 F150 S-Crew FX4, Others
Speaking of research & manuals, does anyone know where to obtain a Jeep shop manual for the JL?
