Tires without a lift
Novee
Nolvia
Atlanta
2020 Sahara unlimited
Hi everyone I’m a new Jeep owner and would like to know what’s the thickest and biggest tires I can get without getting a lift on a 2020 Sahara unlimited JL 4 door?
Honolulu, Hawaii
2020 JLU Sahara
That depends on what you plan to do with it. Do you need full wheel articulation? How much tire rub is acceptable when turning? Does your state care if the tires extend beyond the fenders? Etc.
Blues Fan 30
St. Louis
There's an answer that also limits you on size and that is gearing. The biggest with a stock Sahara is really 33". The 3.45 gearing is not conducive for larger. 33s also shouldn't give you any fits for most all driving conditions. You could probably on road with 35s and only need to perhaps do some minor trimming but performance may suffer due to gearing.
Jeffy56
Payson, AZ
2018 Wrangler Unlimited Sport
I have an Unlimited Sport. I've believe your Sahara has 18" wheels. Mine came off a Sahara (18s) and have Falken tires. 32.6" OD actual per their data sheet. They only slightly rub at extreme articulation and bump. 3.45 gears were horrible, I changed to 4.10s. Gas mileage is 19-23 MPG depending..... 3.6 engine/auto.
Jeep Wrangler JL Tires without a lift 20230213_075219
five9dak
PA
Bikini '20 JL Freedom, '99 Dakota R/T, '11 Boxster
285/75/17 will fit on sport suspension. (sahara)
If you want to keep your 20" baller rims, I don't know.
Plan on a solution to adjust the tire size in the computer- be it your dealership, jscan, or something else.
