TIRE SENSORS WHEN AIRING DOWN.
mrmarco21
JOHN
WA
2018 JEEP WRANGLER UNLIMITED RUBICON JL 4 DOOR
QA Aircraft Inspector
HELLO EVERYONE,
I HAVE A QUESTION? WHEN YOU AIR DOWN FOR THE TRAILS HOW DO YOU GET YOUR TIE SENSORS TO SHUT OFF? WHEN I AIR DOWN TO BELOW 30 PSI MY TIRE SENSORS GO OFF AND MY WARNING LIGHT TURNS ON. JUST WONDERING IF THERES A WAY TO DO THAT? THANKS FOR ALL THE INPUT. JOHN
Guy N Cognito
Nashville
2018 JLU Rubi 2.0t
HELLO EVERYONE,
Why are you yelling?
Can’t the JL Tazer adjust the sensor level? Other than that, most just live with it.
tcari394
Tony
Kimberton, PA
2018 Rubicon JL (2dr)
HELLO EVERYONE,
I use the Superchips Flashcal F5:
https://www.extremeterrain.com/supe...- Tuners|Superchips&T5_Var4=J125938-JL&intl=0
It can do a ton of other stuff too, but I have only used it to adjust the TPMS warning threshold and calibrate my tire size to 35s.
mrmarco21
mrmarco21
JOHN
WA
Sorry I am on my work computer and didn't take off the cap. lock. I'm not yelling by no means. That how we have to do our paperwork.
mrmarco21
mrmarco21
JOHN
WA
Firemadz
York, PA
2018 Wrangler JLU Rubicon, 2018 JLU Sahara
Battalion Chief
I wouldn’t worry about it. Won’t hurt anything. It’ll just be your reminder that you need to air back up when you’re done.
WranglerMan
Will
Katy Texas
2018 Wrangler JLU Sahara
Gas Pipeliner
Tazer JL, Tazer Lite or Flashcal are several choices that can address this, I believe tire pressure on the door is 35-37 # depending on model so the TPMS alerts at 28-30#.
If you have a one of these programmers you can set the low alarm say at 30 so you won’t get the alarm until around 25.
When I go into the TPMS setting from my Tazer to the default factory setting on my JLU Sahara the alarms are set to 35 and I set them to 30 as I run my 315’s in the 28-30 range for normal driving and I get no alarms so you can get a programmer or as stated live with the light as a reminder after airing down
mrmarco21
mrmarco21
JOHN
WA
THANK YOU
Wraif
Kevin
New Jersey
19 2-door manual Rubicon, 09 JKU
Yeah, what they said ! My 2 cents, I let the warning go. Good reminder to air back up.
Chrysler Factory Warranty
