Tire Offset with Clayton Overland Plus 2.5" Lift
Dr. RGB
PA
No longer own a Jeep
So, before I pull the trigger (I apologize in advance, as this may have been posted several times before) and purchase 35" tires, I want to make sure that I have my backspacing and offset calculated correctly, or I might be selling some brand new wheels and tires.... Clayton's website states "4.75 backspacing recommended ". If I were to order a 17x8.5" wheel, in order to achieve the 4.75" of backspacing, I would need to purchase wheels with +0.00mm offset?
Is this correct and does and are there any other recommendations for backspacing?
Thanks in advance! I included a picture of the lift with stock wheels for your enjoyment.
Jeep Wrangler JL Tire Offset with Clayton Overland Plus 2.5" Lift IMG_1569
Hucke_250
Ohio
2018 Unlimited Sport
Yes, 17x8.5 with a 0 offset has a 4.75” backspace.
If you are planning on running a 35x12.5 tire they will stick out approximately 2.25” past the fender.
If you have any other wheels your looking at and have questions on offset/backspace let me know.
BradyW
Brady
Weatherford TX
2021 392XR
If you desire a slightly narrower stance the 5” (real) backspaced XR wheels work fine with 35 x 12.5” tires on 2.5” Overland+ lift. I’m not sure I’d seek them out aftermarket, but if you found a pair of takeoffs for a good price they work without rubbing.
Dr. RGB
PA
Thanks everyone, I ordered the 17x8.5's with the 0.00mm offset and some 315/70's I'll post a picture when everything is completed!
Ezun
Chad
St. Louis area
@Hucke_250
Would love your help on my potential setup, want to make sure there’s no rubbing. I will be taking it to CO for some great trails and mild rock crawling.
2021 JLUR 392
LIFT:
2.5” Clayton Overland+ lift
WHEELS: either
-AEV Salta (17x8.5 with 5.72in Backspace (+ 25mm Offset)) https://www.quadratec.com/p/aev/sal...M7u7YhzqNJvNOGA78-tT2hDjIIk99RLoaAu2GEALw_wcB
-Quadratec Baja Xtreme (17x9 with 4.75in backspace (-6 offset)) https://www.quadratec.com/p/quadratec/baja-extreme-ii-wheel-wrangler-jk-jl-gladiator-jt
TIRES:
Cooper SST Pro 37x12.5/R17
Really appreciate any thoughts / advice!
Dr. RGB
PA
@Hucke_250
2021 JLUR 392
LIFT:
WHEELS: either
TIRES:
@Hucke_250 can double check my math, I would recommend playing around with the Wheel Offset Calculator and the Offset Converter (https://tiresize.com/wheel-offset-calculator/). It will show you how different offsets will move the tire closer and further from your suspension. Clayton is still recommending 4.75 backspacing for the *392* 2.5" OVERLAND+ Lift Kit.
So... Let's look at some of the math:
8.5 in wheel with 4.75" = 0.00mm (recommended by Clayton)
8.5 in wheel with 5.72" = 25mm (AEV wheel)
- The 5.72" backspacing for the AEV will bring the inner sidewall to the suspension and frame 0.98" closer than what is recommended by Clayton. This means, it will likely rub.
9 in wheel with 4.75" = -6mm (recommended by Clayton)
9 in wheel with 4.75" = -6mm (Quadratec)
- Good to go!
For stock wheels, 17x7, Jeep has them set at 44mm. I am not sure of the backspacing and offest for 392 wheels, but I would assume that it is something similar. All of this being said, I am not an expert but the people @Clayton are, so you can give them a call to confirm what would fit with their kits (203-691-8593). When I put the stock wheels on the Overland kit, the rear wheels were rubbing against the sway bars. I threw on some 1.75" spacers and everything was great, but the Jeep looked goofy with small tires. the 4.75" backspacing is perfect. Just an FYI, I got rid of the rear sway links from Clayton and replaced them with Synergy links. All of Clayton's stuff is A++ except the garbage sway links.
Jeep Wrangler JL Tire Offset with Clayton Overland Plus 2.5" Lift IMG_1640
Cookie Monster
Northern Virginia
2019 Ocean Blue JLURT
Hucke_250
Ohio
@Hucke_250
2021 JLUR 392
LIFT:
WHEELS: either
TIRES:
I think @Dr. RGB summed everything up really well in his response.
Dr. RGB
PA
Ezun
Chad
St. Louis area
- Good to go!
Jeep Wrangler JL Tire Offset with Clayton Overland Plus 2.5" Lift synergy_endlink
TY! This is super helpful.
