Tierod, Draglink, Trackbar Brace, & Steering Damper
The draglink was a big pain to get free from the pitman arm, I shudda just pulled the pitman arm right off the bat, and dealt with it off the vehicle. I had to run around town this morning for tools and loctite. So, this has been dragging out longer than I wanted. I also took note that the original Oct 2018 build steering box (I can't tell which revision, because the tag is all faded out) had an unacceptable amount of play at the pitman arm. So, I spent some time dealing with the OEM thread locker on the adjuster before I could adjust it. I got it down to a very small amount of backlash, maybe .010-.020" at the pitman arm. That took a lot of time, working by myself, to make sure I didn't get it too tight and bind across the full range of steering. But then, I'm retired. Slow is ok.
If you're going to install a Synergy sector brace/trackbar brace, you'll need a big ass 42 mm socket and some way to torque the sector shaft nut to 180 lbs/ft. I got by with a 1 11/16" socket, but it's iffy.
The Synergy brace went on pretty easily, but lining up all the holes was a bit time consuming. You have to take the swaybar loose at the link on both sides of the axle. I took it loose at the link to axle location. It really doesn't matter if you choose the swawbar to link location. Either will work. You will need to jack the passenger side to allow the suspension to extend to swing the swaybar down so it's out of the way of installing the Synergy brace. Just do it. It will save you cursing and it is in the instructions to do so. My installation ended up with a bit of misalignment of the trackbar hole where I had to do a few minutes of filing with a rat-tail file. I tried loosening all the bolts and tried to shift it around but it just wouldn't quite align. Not a big deal.
I'm taking a lunch/old timer break right now. But the brace is in and ready for me to re-install the Yeti trackbar and the new draglink and tierod.
FYI
Got it all installed except no room for the Falcon steering damper. I'm running without a damper for a while until I can get the right match of parts. Not going to use it except for the test drive, since the tierod can fall down a bit without a damper supporting it. I set the toe and the draglink for a straight wheel. I drove it 4-5 miles at up to about 55. It seems rock solid. No tendancy to shimmy at all. Steering felt very nice. No real detectable play. But I need to get it up on the freeway for some sustained 70 mph stuff to see if there's any dead area. Maybe later tonight or tomorrow.
Djtlaz123
Destry
Queen Creek , AZ
2018 wrangler Sahara JlU
Djtlaz123
Destry
Queen Creek , AZ
fat_head
2018 JLU
When the dealer replaced my steering box, they used a pickle fork and ripped the boot at the draglink/pitman arm. I just noticed it a couple weeks ago. Now I have to take it back to the dealer and have them fix what they broke.
Drove it on the freeway early this morning. It drove like a $50,000 SUV of the year jeep should drive. One hand at 80 mph, no shimmy on overpasses, no sawing on the wheel, no friggin slop in the steering, Most of all: no "it's a jeep thing". ...and I don't have any steering damper installed, nor do I have 6 or 8 degrees of caster. Hell, I didn't even push in my fuses.
oceanblue2019
Maryland
2019 JLUR 2.0L Auto
Metrology
It's perfectly ok to drive without a steering stabilizer. In fact I like to do that after changing anything in the steering so I can feel what's going on. The steering stabilizers job is to dampen the steering system to help eliminate harmonics, but with good parts properly installed it's not so needed.
Rubi-Zero
Nashville, TN
JL Rubicon , Audi S5
Several members here have been able to make this work. I just recently installed all this stuff myself as well so it can be done with the falcon although It is a very tight fit under there. Turn the Jeep on and turn the wheel to full lock, make adjustments for clearances, then turn to the opposite side full lock and make adjustments for clearances. once that is done then of coarse you will have articulate the suspension and check for clearances again to make sure everything clears.
Yeah, I went thru all that. I had it laying up against the draglink attenuator to clear the trackbar. But with the steering turned left, when the suspension on the driver side gets compressed the Yeti trackbar won't clear the steering damper body. This damper was the Northridge 4x4 recommendation. I'm gonna call Steersmarts for their solution.
20JL Rubi
Georgia
2020 JL Unlimited Rubicon
When you say steering knuckles are you referring to the tie rod ends only or all of the knuckles drag link control arm etc......
Rubi-Zero
Nashville, TN
Now that I’m looking a little closer at your pics, you still have the stock suspension on, correct?
