Jebiruph
(Cross posted on Gladiator forum) https://www.jeepgladiatorforum.com/...vanic-corrosion-mitigation.68354/post-1119797
This post is based on my degree in galvanic corrosion from YouTube university. Please feel free to point out any inconsistencies or inaccuracies.
The latest hinge corrosion TSB includes the use of zinc shims behind the door hinges which indicates that FCA sees this as a galvanic corrosion issue (or at least an issue with a galvanic corrosion fix). For those that don't know, galvanic corrosion results from the direct contact of dissimilar metals. This contact creates an electrical pressure that promotes the loss of electrons into the atmosphere of the less noble metal. Corrosion is the result of the loss of electrons. In the galvanic corrosion world, metals are rated from more noble to less noble, where the more noble metal will cause corrosion in the less noble metal. Since zinc is less noble than aluminum (which is less noble than steel), zinc is used as a sacrificial anode and will corrode (give up it's electrons) in place of aluminum.
Another factor needed for the corrosion to form is the ability for the electrons to be absorbed into the atmosphere. This requires an electrolyte which is typically moisture or. A lack of moisture or water is why metal will corrode less in a dry atmosphere.
So either avoiding contact with dissimilar metals, implementing a sacrificial anode, preventing contact with the atmosphere or any of the above should help mitigate galvanic corrosion. To that end, here's what I've thought of so far.
The zinc shim currently being used by FCA as a sacrificial anode will be great when they are available, but as an alternative how about a zinc washer on the door hinge. Time (or opinions) will determine the effectiveness of this.
Here's what a m10 washer with a 20mm outside diameter looks like on the door nut.
Here's one with black permanent marker around the edge so it doesn't show as much.
All of my door hinge corrosion has started at the pin, which I attribute to that being the connection to the dissimilar metal in the rest of the Jeep and also to damage done to the paint from opening and closing the door. My plan is use these Delrin hinge liners to replace the metal hinge liners to both electrically separate the hinge from the body and to also provide a more paint friendly surface for the hinge to pivot on.
And since access to the atmosphere with the presence of moisture or water is also needed for galvanic corrosion, my thought here is to apply strips of paint protection film around the lower edges of the panels to help isolate these corrosion prone areas from moisture and the atmosphere. No pictures of this yet.
