Thoughts on 3.6 longevity
  • Thread starter Deleted member 57375
  • Start date
  • Watchers 19
TheRaven
Reading, Pennsylvania
Sold
He also only does 4 tire rotations, which that does bug me. I SOLD YOU A PERFECTLY GOOD SPARE SEAN, GET YOUR MONEY OUT OF IT!
OH MAN you are going to love this - I also only do 4 tire rotations.
Jeep Wrangler JL Thoughts on 3.6 longevity {filename}
yokramer
Snark Incarnate
Who doesn't use full synthetic? You mean there are people on here that don't?
Quality oil is quality oil .... change it often and youre fine
yokramer
Snark Incarnate
Remorseless
NC
Cool, so trading 3.6l problems for 2.0l problems like I said.
Eh, it's the same problem and therefore cancel each other when comparing the two, being as its not a unique problem and isn't either lost or gained anew. Call it a Jeep problem instead of a 2.0 or 3.6 problem (though, probably rare on either engine given volume of production and issue occurrence rate, but that's the other thread).
But, given that, any other problems?
Remorseless
NC
Remorseless
NC
@Sean L - just go ahead and rotate it. It's not too late. Better now than never.
Sean L
Sean
North Carolina
Seems like a waste of money on a spare
Its there in case I get a flat. If I get Falkens again I'll probably work it into the rotation, but they just wore down faster than I thought they would.
Remorseless
NC
Well, we can’t put the toothpaste back in the tube now can we ? ….. 4 tire rotations ,:facepalm:.
So you're a 5 tire guy then Roky?
SlickRicksWilly
2024 JLW (ordered)
I was reading about the issues with metal inside the 3.6 . I have a 2018 jl unlimited with the 3.6. I would like to know the mileage of the first oil change and all after that,also was the engine broken in properly. I would like to hear feedback from the people who have had this issue with their 3.6
My wife's 2018 sport had the motor replaced at 105k miles. I am pretty sure the metal in the engine was pre installed by the factory 😆. Oil changed when the screen on the dash told us it was needed, plus or minus a couple hundred miles. 0w-20 Mobil One, except for the first 2 Jeep wave oil changes. Don't know what they used.
I am pretty sure that it's just a crap shoot of which engines will have problems. I now have 2 new 3.6 engines, maybe I will run different oils in each one but probably not. Ask me again in about 7-8 years how they are holding up.
TheRaven
Sold
Yeah exactly. I buy four new tires and a takeoff to mount in the spare location. Its only getting used to get to the tire shop.
Remorseless
NC
I am…..but not at the moment, my spare has a plug in the sidewall….🫤
Sounds like you need to replace the whole set with tires a size or three bigger
