Thanks, I bought one on eBay for $200. Turns out there's two different versions and I got the non-rubicon one, which holds the tire about an inch lower closer to the bumper. Any way, now I have a spare camera if any one needs one.Well it’s less than half that for the whole spare tire assembly here:
https://parts.allmoparparts.com/oem-parts/mopar-spare-tire-bracket-assembly-68474050ac?c=Zz13aGVlbHMmcz13aGVlbC1zcGFyZSZsPTEmbj1Bc3NlbWJsaWVzIFBhZ2UmYT1qZWVwJm89d3JhbmdsZXImeT0yMDE5JnQ9dW5saW1pdGVkLXJ1Ymljb24mZT0zLTZsLXY2LWdhcw==
If you need just that part, why not post and ask? Someone is bound to have it and will probably sell it to you cheap, or maybe free. I’ll check tomorrow if you need just that part.
I just think that jeep should have put more thought into the design allowing the individual studs to be replaced.I see one of the studs is damaged, if you are handy you can grind off the tack welds and replace the stud with a normal bolt... not a biggie since you don't need to torque the spare tire a lot..
if you are not handy perhaps a shop or a friend can do it for cheap or free
That wouldn't make any sense. The vast majority of them never even see a different tire, no reason to make a part like that. I just threw mine out a couple weeks ago. It was slightly bent from a small rear end accident. I'm glad it bent and not my tailgate. Now I have a CavFab carrier. LolI just think that jeep should have put more thought into the design allowing the individual studs to be replaced.
I'm sure the stud got damaged when I had 315/70's put on the stock rims, I seen them wrestling with the spare pushing it back against the bump stops.That wouldn't make any sense. The vast majority of them never even see a different tire, no reason to make a part like that. I just threw mine out a couple weeks ago. It was slightly bent from a small rear end accident. I'm glad it bent and not my tailgate. Now I have a CavFab carrier. Lol
The guy that hit me, his hood hit the spare. After the accident. I couldn't tell anything was wrong other than some small scuffs on my Fishbone rear bumper. I went to delaership anyway and that when we found that one of the lugs was slightly bent. He hit me at like 15km/h.I'm sure the stud got damaged when I had 315/70's put on the stock rims, I seen them wrestling with the spare pushing it back against the bump stops.
Impact wrenchThe guy that hit me, his hood hit the spare. After the accident. I couldn't tell anything was wrong other than some small scuffs on my Fishbone rear bumper. I went to delaership anyway and that when we found that one of the lugs was slightly bent. He hit me at like 15km/h.
I can't even behind to understand how your issue happened.
