Bleda2002
Resale sucking is highly unlikely in the average time a person has a car of 3-5 years because the warranty is 10 years. The 4xe will have the same resale value as most jeeps in that time period.you misread! What we experienced is that the 4xe had the “neck snap” off the line. But that’s it. Put a Wrangler 4xe next to a 392 XR, and all the 4xe is going to see all the way to top speed and the 1/4 mile is 392 taillights . And then the 4xe will suck at resale when the owner decides to move on
The 392 could be argued as a collectible but then it really means that it's low miles, nearly stock, and not rashed which for a jeep sounds boring.
As for fuel savings, there 4xe is not more expensive that a similarly optioned Rubicon or Sahara when the 7500 is factored in. In most cases it's actually cheaper. You can get a less optioned Rubicon or Sahara for less, but apples to apples they're more or less even. If you fit the 4xe use case of lots of short trips with an hour or 2 to charge every 20 miles the savings are substantial and easily off set any resale value and then some.
