AZDIESELRUBI
Why anyone would buy a wrangler to tow - if you need an Exhaust brake you are over your 3000lb towing limit.
Ranger band! The cheap, easy, bulletproof solution to unwanted key-stabs that I've been using since day one. Also can be used as fire tinder if needed. They're a real godsend for a multitude of applications2. Has anyone found a good way to keep the switchblade key from opening in your pocket all the time?
Man I don't have any laying around...lots of other gear...actually too much haha...but none of those. Will pick up a pack. Nice idea. Does it help prevent the accidental horn noise? Three times in three weeks with keys in pants pocket or hoodie pouch I bumped a counter or something and the neighbors were alerted that I bought a new Jeep...Ranger band! The cheap, easy, bulletproof solution to unwanted key-stabs that I've been using since day one. Also can be used as fire tinder if needed. They're a real godsend for a multitude of applications
I did not know previous discussions were in place, or if it was a diesel specific thing. Thanks for letting me know. I agree with your decision. As for the film, I'll be digging into it again this weekend adding some things that brown santa brought me and will look good in the daylight.That bracket has been discussed in depth here for a while now. The consensus is it was put in place to address the side impact rollover crash test I believe. Several folks have removed them or cut them off, though I personally left mine in until the day I get it hung up on a rock.
As for the oily film on that part, not sure. Could be something left over from assembly. Iād spray it off with degreaser and monitor the area, if it returns you probably have a fluid leak.
Itās not diesel specific, I think it started showing up on ā22 models? Itās bizarre they only incorporated it on one sideā¦I did not know previous discussions were in place, or if it was a diesel specific thing. Thanks for letting me know. I agree with your decision. As for the film, I'll be digging into it again this weekend adding some things that brown santa brought me and will look good in the daylight.
I would imagine so with the added thickness. Though the most surefire way would be to disable the panic button via Tazer, which is also a thing I did on day one lol. I had a Compass where the panic button would accidentally go off all the time, so annoyingMan I don't have any laying around...lots of other gear...actually too much haha...but none of those. Will pick up a pack. Nice idea. Does it help prevent the accidental horn noise? Three times in three weeks with keys in pants pocket or hoodie pouch I bumped a counter or something and the neighbors were alerted that I bought a new Jeep...
3,000 lb towing limit? 3,500, right?Why anyone would buy a wrangler to tow - if you need an Exhaust brake you are over your 3000lb towing limit.
Maybe... I didn't pay much attention because that's not what I bought it for.3,000 lb towing limit? 3,500, right?
Yeah JLU is 3500.3,000 lb towing limit? 3,500, right?
I know they say there's not a break in period for the EcoDiesel. There is definitely a distinctive point in time right around the 12,000 mi mark where you start noticing you getting better mileage doing the same stuff you were doing prior to that point.9. I think the EGTs must be really low on this 3.0L because it likes DEF. 1/4 tank in 1,000 miles and very, very little around town driving / short trips.
