- Banned
Here's what I think I know. If wrong set me straight. : - )
When cold cranking the 3.6L JL the starter relay is, if only for an instant, solely dependent upon the ESS battery to communicate to the starter.
Otherwise, at all other times, the ESS and main batteries are connected in parallel, free, along with the alternator when the JL is on, to charge each other/get charged (assuming the ESS battery can accept a charge and isn't broken.)
Why do you think FCA designed the small battery of a non-essential system (ESS) the critical task of powering the starter relay?
Even if the ESS battery fails while the vehicle is running, the ESS system won't engage, to need the vehicle's starter relay to signal the starter to restart the stopped JL in the first place--right?
I'm very confused. I don't even know if my prior paragraph is factual. To this point, are separate starters or mechanisms involved in cold cranking, versus ESS cranking the vehicle?
Thank you.
Thank you.
