The Parallax - Sting Gray JLUR Build
T4STE
T4STE
Allen
Belleville , NJ
oswachiart.wixsite.com
2020 Jeep Wrangler Rubicon Unlimited
Graphic Designer
You are probably aware of this… AAL designed their own Pack Out bases since the Milwaukee ones were too large for their storage shelf. I just ordered 6 of them. Four for my trailer and 2 I’ll use inside the Jeep.
yes I am aware. Which may still be the route i take depending on how my platform turns out since im moving things around to see the best possible configuration of my trunk space lol.
T4STE
T4STE
Allen
Belleville , NJ
Graphic Designer
Got the platform in today. A few minor tweaks but I got it in there.
the tubing for the base. Mounted to the floor. The 6 outer bolts will sandwich the platform and tubing to the floor.
It fits. Took some tool box liner and spray adhesive it onto the platform.
I left the outer edges bare as I will take the d-ring tabs off the outer bolts. I have two of these L bracket rails(thick ones) to mount on the outer edge to be the anchor points. I hate how the d-ring anchors aren’t further out to the sides.
i will probably order the AAL Packout base next week to mount on the platform. I got more measuring to do cause I want to build a small cubby box for the spot between my Milwaukee tool box and the back seat. This is how it looks as of today.
i figured I’d go with the AAL Packout base for now as it is low profile and also eventually when I get their cargo rack. I will relocate it up there. So for now this is my trunk setup and hopefully this gives peeps ideas of what they can do for storage in the back. There are plenty other ideas out there and on this page. Cheers!
T4STE
T4STE
Allen
Belleville , NJ
Graphic Designer
I also relocated some blankets and my camp chairs under the back seats as it is unused space.
T4STE
T4STE
Allen
Belleville , NJ
Graphic Designer
I added the rails today. Threw on some black paint but will probably redo the paint when I mount the Packout base and paint both. I removed the d-ring tabs after I took the pic. as the rails are the new anchor. I will most likely reuse them on another project.
T4STE
T4STE
Allen
Belleville , NJ
Graphic Designer
First doorless day of the season today.
T4STE
T4STE
Allen
Belleville , NJ
Graphic Designer
Took the scrap pieces left from my trunk platform project to make a small cubby behind the seat to sit between the back rest and where my Packout tool box will sit. Gotta figure out a modular way to mount it for when I need to take it out when the whole trunk is needed.
T4STE
T4STE
Allen
Belleville , NJ
Graphic Designer
Base camp for the weekend. High Point, NJ
T4STE
T4STE
Allen
Belleville , NJ
Graphic Designer
It was a great night of camping.
T4STE
T4STE
Allen
Belleville , NJ
Graphic Designer
The 37 Pats look way larger then the 37 KM3's what do they measure at?
Love the build and name!
I think there at 36.7 or somewhere along that. Mine are so worn now that they’re probably 35’s. If you rotate them properly you can get 35k-40k out of them just fine.
T4STE
T4STE
Allen
Belleville , NJ
Graphic Designer
T4STE
T4STE
Allen
Belleville , NJ
Graphic Designer
Found a trail on our way home. I was worried we’d get home and the Jeep would still be clean. Crisis averted.
T4STE
T4STE
Allen
Belleville , NJ
Graphic Designer
So after the camping trip last weekend I’ve come to realize that I didn’t have a hatchet. We had plenty of fire wood during the trip but not enough to keep the fire burning for long. A hatchet would’ve done great work of that so it was time to pick one up. Also to mount it, I picked up these small tool holder usually usually used for garden shovels etc to mount the hatchet. I attached the mounts to my new home brew cubby box behind the seat.
the mounts holds the hatchet tight and secure. For now it will do. I will probably get a set of quick fists clamp mounts to have it fully secured at a later date. For now, that bad boy ain’t goin nowhere.
T4STE
T4STE
Allen
Belleville , NJ
Graphic Designer
So this finally arrived today. Can’t wait to lock my toolbox down securely lol.
Rubitrux
