If you mean tuning, not at this time, on the FC+.Amy plans for any performance upgrades to be added?
I need to confirm the 1 and 2, 3 is a yes for sure.On the fence between Flashcal+ or Tazer Mini. Flashcal+ seems great with the user interface, but fairly new and buggy based on thread feedback. I know this shares some of the Tazer Mini features, but does it have:
1. AutoPark disable
2. Triple Honk disable when temporarily stepping out of running/parked vehicle
3. Any plans for future feature adds
I have a 2022 JLUR and already have a security bypass module for use with OBD scanner, can I just get a Flashcal+ w/o the bypass module that will work with my ‘22 JL, i.e. part 3581?
Appreciate the feedback.
Turn the vehicle of and let it sit for a while with everything off. Give the Jeep's network and modules all time to power down. Those kinds of things happen when modules lose communication with other modules. And that will always happen when reprogramming. After everything has powered down and been sitting for while, go ahead and turn the ignition on again. See if everything works. I've seen things like this happen with weak batteries too. How is your battery? Since programming is happening without the engine running make sure your batteries are good or hooked up to a charger. If voltage dips enough different modules may start to act up and report errorsHello friends! I have problems, please tell me where to turn. After installing flashcal+ on jeep gladiator jt 2022, the error ACC FCW came out (cruise control, collision warning), I just can’t fix it. I left a request on the support website, but did not receive a response. There is a problem with the vehicle and the collision agreement module is not working. The computer constantly produces many different errors. There are no installation instructions or manuals flashcal+ anywhere.
dear friend thank you for your help! I tried to make the car fall asleep and wake up by turning on the ignition, turning off the ignition and waiting for the screen to go out, I did this several times - it didn’t help, the error remained. I completely disconnected two batteries, reset all settings on the radio system display - it didn’t help, the error remained. I tried to reset the errors via Flashcal+ - it didn’t help, the error remained. I completely removed the Flashcal+ unit and disconnected the battery - it didn’t help, the error remained.Turn the vehicle of and let it sit for a while with everything off. Give the Jeep's network and modules all time to power down. Those kinds of things happen when modules lose communication with other modules. And that will always happen when reprogramming. After everything has powered down and been sitting for while, go ahead and turn the ignition on again. See if everything works. I've seen things like this happen with weak batteries too. How is your battery? Since programming is happening without the engine running make sure your batteries are good or hooked up to a charger. If voltage dips enough different modules may start to act up and report errors
Have you heard back from our support team? Can you give them a call if possible, at 407-585-7000Hello friends! I have problems, please tell me where to turn. After installing flashcal+ on jeep gladiator jt 2022, the error ACC FCW came out (cruise control, collision warning), I just can’t fix it. I left a request on the support website, but did not receive a response. There is a problem with the vehicle and the collision agreement module is not working. The computer constantly produces many different errors. There are no installation instructions or manuals flashcal+ anywhere.
I just replaced a TazerJL Lite with a FC+ yesterday, and after setting Tire Size (which caused ABS resets etc.) I too have the same issues now....Hello friends! I have problems, please tell me where to turn. After installing flashcal+ on jeep gladiator jt 2022, the error ACC FCW came out (cruise control, collision warning), I just can’t fix it. I left a request on the support website, but did not receive a response. There is a problem with the vehicle and the collision agreement module is not working. The computer constantly produces many different errors. There are no installation instructions or manuals flashcal+ anywhere.
If you set it back to the stock tire size, does the issue go away? This is a 19 JL?I just replaced a TazerJL Lite with a FC+ yesterday, and after setting Tire Size (which caused ABS resets etc.) I too have the same issues now....
2019 JLUR 3.6. I will try that later today and contact Tech Support if it doesn't resolve the problem.If you set it back to the stock tire size, does the issue go away? This is a 19 JL?
407-585-7000 if needed.2019 JLUR 3.6. I will try that later today and contact Tech Support if it doesn't resolve the problem.
I have same issue with ACC & FCW warning lights appearing after programing new tire size with FlashCal+ in my 21 JLU w/3.6L App Version: 1.4(41) Firmware Version: 7.1 / 1.40Have you heard back from our support team? Can you give them a call if possible, at 407-585-7000
Thanks
